Wheel lug nuts for spoke rims
Old Jan 3, 2012 | 07:22 PM
lenray's Avatar
Default Wheel lug nuts for spoke rims
HAVE AN 84 XJS having trouble finding lug nuts for the spoke rims. They are 1 1/4 inch. long.
Also the front and rear wheel studs are different--is that correct.
Thanks for any help.
len in michigan
Old Jan 3, 2012 | 07:25 PM
lenray's Avatar
Made a mistake on the above post--the the wheel lug nut is 1 3/4 inches long-----one inch three quarter LONG. sorry
len
Old Jan 3, 2012 | 08:09 PM
87XJSCoupe's Avatar
I'm doing some guessing here since I have an 87. My wheel studs are all the same. They are 1/2" X 20 thread. If you have Dayton Wire Wheels you might check these out to see if they are the ones you need.
Dayton Wire Wheels 3-0150 - Dayton Wire Wheels Lug Nuts - Overview - SummitRacing.com
Old Jan 4, 2012 | 07:03 PM
lenray's Avatar
Many thanks for the info. My wheel lug is 1 3/4 inches long. The info. states the lugs are 1.6 inches.
Do you know the length of the ones you have????
I think you have me on the right trail. Many Many thanks.
len in michigan
Old Jan 4, 2012 | 09:06 PM
87XJSCoupe's Avatar
I don't have wire wheels but I know that the Jaguar XJS has 1/2 X 20 studs. You can identify your lug nut from one of the old ones to see if it is a conical seat, standard or bulge. For my alloy wheels it requires the 60 degree conical seat, bulge type. Mine are open ended. For your wires, you will need to determine if the seat is a standard conical or bulge conical. The length is determined by what is required to cover the stud since yours are closed ended. Once you determine the seat and the length you need, any style can be used from any manufacturer. Here is a little more reference material that might help make this all clearer. Compare your old one to the charts to determine the seat.
http://www.mcgard.com/files/pdf/lugnutref2009.pdf
Lug Nuts - Cone Seat - McGard: Innovative Security Products
hunter34
19
Sep 14, 2022 11:09 PM
DrTripp
Mar 22, 2020 09:33 AM
lickahotskillet
Oct 18, 2015 09:51 AM
Matei Dima
Oct 8, 2015 11:45 AM
ferraripete
Sep 10, 2015 01:24 AM
