Wheels for XJS
Old Aug 6, 2014 | 10:10 PM
gregh's Avatar
Default Wheels for XJS
Hi, Apologies for not posting in a while, been putting the long hours at work and travelling some on weekends.(Yes, in the '89 XJS Convertible), put approx. 6,000 kms since out of winter storage, working pure.
Does anyone recoginze these rims, and based on the info listed below, will they fit my '89?
View larger image
Date Listed01-Aug-14Price$350.00
Address
View map
Tire size (diameter) 16 in. SET JAGUAR RIMS 16 X 7.5 and Caps
The rim has the following is stamped in the rim
TSW 7.5JX PCD
16H2 ET
The nuts have stamped 1/2
R4
Old Aug 7, 2014 | 02:19 AM
Flint Ironstag's Avatar
Ha! I looked at them and immediately thought TSW, then finished reading your post. Yeah, definitely TSW but I don't know about the fitment. Should look great on your XJS!
Old Aug 7, 2014 | 03:18 AM
AL NZ's Avatar
put those on an XJS and people will think you really hanker for a Bristol !!
Old Aug 7, 2014 | 03:43 AM
AL NZ's Avatar
Old Aug 7, 2014 | 11:17 AM
orangeblossom's Avatar
View larger image
Address
View map
TSW 7.5JX PCD
16H2 ET
R4
Hi Gregh
It looks as though the wheels you have there are a discontinued pattern, which were called 'Web' made by TSW one of the largest manufacturers of Alloy Wheels.
The piece of information you are missing is what is called the PCD Pitch Circumference Diameter.
Which is an Imaginary Circle drawn through the Center of the 5 Bolts, which is what determines, if it will bolt on your hub.
5 Stud PCD is not enough, you DO NEED to know the measurements of the PCD.
Plus is the Offset suitable for your Car?
Have a look at the Info attached and that should hopefully help to give you a much better idea.
Cheers O.B.
Determining your bolt pattern | eBay
Alloy Wheel Offset Technical Help - Offset or ET diagrams and text information to help you understand alloy wheels offset
Discontinued Wheels
H20boy
Dec 24, 2024 03:23 PM
Rivguy
Dec 4, 2020 07:55 AM
PMKimpton
Aug 3, 2019 08:22 PM
Armor6
Sep 14, 2015 07:56 PM
metalmarty
Sep 11, 2015 07:05 AM
