Where is the intake manifold cartridge for brake booster
Old Dec 30, 2014 | 10:46 PM
Vee's Avatar
Vee
Default Where is the intake manifold cartridge for brake booster
Where is NBC3184AA on the AJ16 engine?
It is the intake manifold cartridge for the brake booster.
JDHT does not shown where it's at.
Old Dec 31, 2014 | 07:17 AM
petemohr's Avatar
Old Dec 31, 2014 | 07:36 AM
Doug's Avatar
That pic from the parts catalog illustrates the part itself....but not the location!
I've never heard of it before so my curiosity is piqued. What function does it serve?
Old Dec 31, 2014 | 07:47 AM
Brake buster's Avatar
well, looking at the diagram , and item 2 is a core plug for this end, one would assume that the ' cartridge ' goes in a similar hole at the other end ??
as to function , it's the tap off from the induction manifold to provide constant vacuum to the brake booster while the car is running, and has a built in screen ? to stop debris going one way or the other
BB
Old Dec 31, 2014 | 09:19 AM
Roger95's Avatar
It's located right at the end of the brake booster hard line as it enters the intake manifold. It is the small brass fitting mounted in the manifold through which the hard line passes. The plastic "cartridge plug" is not used and the brass fitting "locks" the hard line into the manifold.
Old Sep 24, 2015 | 01:25 PM
Teck4Jag's Avatar
this part work on newer cars also,just not cataloged for then on the aj16 cars
clubairth1
30
Sep 3, 2025 04:38 PM
dsnyder586
Dec 29, 2024 07:39 PM
xjrjag
Oct 24, 2024 03:09 PM
rusty37
Sep 18, 2015 10:03 AM
ayavner
US Southwest
Sep 16, 2015 02:43 PM
