Who is the Transmission Guru ???
Old Jun 5, 2019 | 02:56 AM
Kriss Vector's Avatar
Default Who is the Transmission Guru ???
Hey guys i,m looking to tackle this nasty 30 year old transmission leak this weekend, However i cant remember if this is a Borg Warner 12 or a GM 400 Can any of you tell by the horrible oil stained picture i took.. Thanks in advance. 1976
I,m thinking it is a Borg Warner 12 ( if i remember correctly ) Thanks
Old Jun 5, 2019 | 03:17 AM
Looks BW12 to me, but its many years since I looked.
Is the vac modulator on the RH side of the casing, just above the gasket line, near the front = TH400
Vac modulator on the LH rear, on the reaa face = BW12.
XJS had TH400 , the earlier XJ12 had the BW12, but the crankshaft was different also on the V12, to take the converter snout, sooooooo, being a Chev, and maybe a 5/8 crank hole, a BW12 was used, as that converter has the snout to suit that hole. The TH400 snout was more a "dome" as apposed to a "shaft" style of teh BW12.
Old Jun 5, 2019 | 03:31 AM
I will put it up the ramps and look under it, but it is being run by a chevy V-8 so it makes me lean towards the BW Thank you. I will let you know as soon as i get under it.
Old Jun 5, 2019 | 06:40 AM
Doug's Avatar
The BW12 pan gasket is almost square. The TH400 is very irregular.
As far as I know the XJS used the BW12 until May 1977 or thereabouts
Old Jun 5, 2019 | 07:25 AM
You guys are the BEST! !!!!!!!
richardjay
Dec 13, 2016 07:48 AM
AllblueACR
Sep 14, 2016 12:15 PM
JLG
Dec 20, 2015 11:05 AM
hotel_gm54
Jun 25, 2013 07:14 PM
sidewalkman
Nov 9, 2010 03:15 PM
