Window and Mirror Woes
Old Jul 18, 2023 | 09:37 AM
dinodino's Avatar
Default Window and Mirror Woes
Hello All,
My 1990 XJS convertible has suddenly decided that the driver's mirror (RHD), driver's door window, and driver's quarter window should all stop functioning at the same time. I've looked at the 1990 MY electrical diagram, and it's not clear to me what single component would cause this. Does anyone have any guidance?
Best regards,
Dan
Old Jul 18, 2023 | 02:42 PM
Vee's Avatar
Vee
Yeeesh. What if the wires leading into the right side of the car got severed, fried, or shorted somehow?
Door speaker still works?
Old Jul 18, 2023 | 03:25 PM
ptjs1's Avatar
Dan,
I can't see anything that links those 3 circuits, even earth points.
I suspect you've got either 2 or even 3 coincidental problems.
There's the obvious linkage between the mirror and front window insofar that the wires pass through the A-post and thence into the door. I'd start my examination there.
As regards the rear window, I think that's a coincidental problem. Start by swapping the left and right relays and see if the problem changes sides. If not I would check the output voltage from the relay when the window is being operated (immediately on lowering the hood, 8 seconds delay when raising it). If you can see output voltage, then you've either got a wiring problem to the motor or a motor problem. Remove the trim panel and apply voltage direct to the motor connection and verify the motor integrity.
Good luck
Paul
Ant Buck
Jun 12, 2023 12:46 PM
Slimjim
Mar 31, 2023 12:04 PM
synperkaya
Feb 22, 2013 09:06 PM
oz1701
Mar 1, 2011 07:17 PM
