Window motor driver's side
Old Jul 9, 2017 | 03:33 PM
Leod1948's Avatar
Default Window motor driver's side
I need a driver side window motor for my 1989 Jaguar XJS convertible V-12. I can not find a new or rebuilt one. I would appreciate any suggestions where I might find one.
Old Jul 12, 2017 | 11:55 AM
Leod1948's Avatar
I'm not sure but I think I just bought the last driver side window Jagbits had. It was the only place I could find one.
Old Jul 12, 2017 | 06:28 PM
sidescrollin's Avatar
Can you just use a XJ6 motor? Pull yours so you can check the teeth and bolt pattern before buying.
I had a weird motor on my 88 and had to get a totally different regulator because I couldn't locate another with the same teeth.
Old Jul 13, 2017 | 02:01 AM
Greg in France's Avatar
If nowhere else, Andy Harvey at Just Jags in the UK will send you one.
Old Jul 13, 2017 | 12:09 PM
MHF25's Avatar
LeRoy.. Classic Car Garage, Jacksonville, FL. Email: parts@classiccargarage.net
He is in the phone book.
I have bought parts for my XJS numerous times from him.
Old Jul 15, 2017 | 12:08 PM
Doug's Avatar
There were 2-3 variations of XJS window motor circa 1988-1990. Confusing. Nowadays some replacements require an adapter kit, sold separately, to work on certain models.
When the motor failed on my '88 I went to the local parts store and we easily found a matching *motor* which was swapped onto the Jaguar-specific *drive mechanism*. Took five minutes for that and another five minutes to change the wiring connectors. This way no adapters are needed to mate-up with the existing window regulator.
Also, I just gotta believe that there are companies who rebuild window motors.
