Wires in the V
Old May 30, 2015 | 11:39 PM
darrhel's Avatar
Default Wires in the V
Greetings
While cleaning out the V I found two wires running along the bottom right hand side, both covered in oil and crap as you would expect.
Both running the length of the V and coming out under the AC.
The green wire with the blue stripe went off to the right to the temp sender at the front in of “A” bank. ( this one has now been rerouted out of the V.
The other one, a lighter green with a brown / slate stripe went off to the left to the front of “B” bank and was not connected but had a straight connector spade on it, the first time I had noticed this particular wire. The engine temp and air intake sender on the left side are intact with no missing or broken connectors. Can not see where this would connect to but will keep looking….!
Any comments on what this wire is for or checks I should do would be much appreciated.
Darren
Old May 31, 2015 | 12:56 AM
baxtor's Avatar
I think that wire is for your A/C compressor.
Old May 31, 2015 | 08:14 AM
Katoh's Avatar
Had the same problem, will just simply refer you to this thread.
https://www.jaguarforums.com/forum/x...hey-go-114202/
Old Jun 1, 2015 | 12:21 AM
darrhel's Avatar
Default Thanks Baxtor and Kato
Yes it was the AC wire as you suggested, all fixed and sorted and re run out of the V
much appreciated
Darren
Poet
Feb 7, 2025 02:18 PM
jagent
Jun 5, 2022 02:18 PM
Rocky15
Sep 28, 2015 04:59 PM
FabCat
Sep 26, 2015 12:16 PM
driver safz
Sep 26, 2015 06:01 AM
