XJS 1986 12 cyl. Fuel injectors rebuild issues
Old Nov 4, 2019 | 07:25 AM
Parketog Malun's Avatar
Default XJS 1986 12 cyl. Fuel injectors rebuild issues
Hi. Who can rebuild my fuel injectors.
Í have v12. 1986 módel.
Chassic number is Chassis n- SAJJNAEW4BC135401
Old Nov 4, 2019 | 07:29 AM
Doug's Avatar
As mentioned in your previous thread, here's one possibility:
https://www.jaguarfuelinjectorservice.com/
Old Nov 4, 2019 | 08:49 AM
Welcome to the forums Parketog Malun,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to XJS forum. This is the place to post questions about your model.
Old Nov 7, 2019 | 03:37 PM
Dleit53's Avatar
How much of a do it yourselfer are you? I have had success by removing the injectors, obtaining a plug to connect them to a battery through a push button switch, and using carburetor cleaner, compressed air, and WD40, pushed back and forth through the injector with compressed air. This does both atomize the carb cleaner and WD40, while making sparks inside the switch, so there is significant fire hazard if not done in a well ventilated area, and care must be taken to keep the sparks away from the fluids. I put the air pressure to about 40 psi, or 3 bar, and use a 8 mm hose on an air gun to force the fluids back and forth through the injectors. If one is careful, handy working on cars, and understands what I am suggesting, you can do a fair job of cleaning your own injectors at a very low cost. If this sounds like more than you can handle, contact an automotive professional.
Old Nov 7, 2019 | 06:46 PM
Rescue119's Avatar
Check out living with a classic on youtube. He did a rebuild video not that long ago.
Parketog Malun
Nov 3, 2019 05:18 AM
Jaesteban
Oct 6, 2019 12:19 AM
Dmac
Oct 1, 2017 01:21 PM
Jaguar2986
Sep 7, 2013 11:37 PM
alicat
Jul 6, 2010 09:20 AM
