XJS air intake.
Old Feb 10, 2009 | 12:42 PM
Cadillac's Avatar
Welcome , thanks for your comments on our great forum as well .
For your inquiry , you may use General Tech Help Forum or XJS Forum so that you can take attention of our tech guys
Old Feb 10, 2009 | 01:08 PM
JagtechOhio's Avatar
Greetings,
Tha auxilliary air valve on the V12 is a temperature controlled air bypass valve that controls engine idle speed. It is located at the back of the left intake manifold, and draws inlet air from the left air cleaner only.
The balance pipe that connects the two intake manifolds at the rear distributes air equally to both sides of the engine: so even though most of the air at idle is entering through the left air cleaner only, all is well. If your engine performance is good, both air cleaner snorkels are sucking just fine as you drive down the road with the throttle plates open. All normal.
Old Feb 10, 2009 | 06:53 PM
Hey canadianjag n welcome to the forums
Glad you got the answer you're lookin for......As this is the new member section I'm going to move this to the General tech help section.
Perhaps you'd like to add another post in the newbie section with an intro bout you, your car etc etc?
1100me
Jul 24, 2023 06:10 PM
02jagstype
23
Oct 23, 2022 07:03 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
1964Daimler
Sep 9, 2015 11:28 AM
1100me
Sep 7, 2015 06:26 AM
