XJS alarm remote
Old Jul 28, 2021 | 01:48 PM
mat-stoke1's Avatar
Default XJS alarm remote
Hi,
I wonder if anyone can help. I’ve got a ’93 4.0 XJS (VIN xxxx189559) that has always had 2 (non-transponder) keys but only a single remote; something I’ve finally decided to try to address since I don’t like having a single point of failure. This existing remote seems to be after-market since it has no Jaguar branding and the PCB is stamped as being ‘Tech Tronics’ but I wonder if it is simply a replacement fob for the OEM system since the alarm seems to respond with the expected ‘chirps’ and ‘warbles’ that I have seen mentioned online.
With that in mind, if the alarm is OEM, can anyone advise where it would be normally located? Also if it is OEM, is there a simple way of determining whether it would operate at 318mhz, 418mhz or & 433mhz and which of the long list of fobs I might need? At the moment I’m rather lost in a list of DBC100852, DBC10086, DAC6160, DAC7970, DBC10085, DAC7990, DBC100842.
Again, assuming the alarm is OEM, I’ve seen a couple of processes mentioned to code the replacement/additional fob to the car – one involving a ‘valet switch’ (Is DBC12022 correct?) that my car does not have. Again, is there a way to identify which method will be needed since I have also read that the ’03 XJS might not have the wiring for the valet switch under the centre console lining.
Thank in advance 😊 😊
Old Jul 28, 2021 | 03:07 PM
malc4d's Avatar
It helps if you say where you are.....
The oem alarm works on:
The UK had 418Mhz others had 433 and the US has 315-8 mhz. You will find it behind the right (passenger) tail light. It bolts onto the lower fixing bolts. There are some programable remotes on Ebay that can be programed to the alarm. Jaguar remotes are rare and will cost a fortune.
Do you have a red led light on the ciger lighter or on the steering control column with a small switch ?
Old Jul 28, 2021 | 03:21 PM
mat-stoke1's Avatar
Hi,
Thanks for the quick reply - there is a light behind the cigar lighter; cant remember ever noticing it illuminate though however the 'security' light on the stereo is active
Old Jul 28, 2021 | 03:22 PM
mat-stoke1's Avatar
Also forgot to say, no sign of a switch on the steering column
Old Jul 28, 2021 | 03:31 PM
malc4d's Avatar
Light on cigar lighter is for the alarm. It should flash . Radio light has nothing to do with the alarm. Did you look in the boot/trunk for the alarm ? ?
Jaguar changed the alarm system somewhere mid 1993. Yours looks like the later one without valet switch (or its in the armresrt box)
Old Jul 28, 2021 | 03:39 PM
mat-stoke1's Avatar
Hi, it is dark and rainy here now in the UK but - assuming the weather improves - I'll be taking a look tomorrow and will let you know what I find. I'm hoping for an OEM alarm but I am not convinced that is what I will find - this is the current remote:
Old Jul 28, 2021 | 09:23 PM
kansanbrit's Avatar
https://www.ebay.com/itm/Fits-1993-1...-127632-2357-0
This worked on my 94.
malc4d
Sep 20, 2015 02:12 PM
hawaiianjag
Nov 16, 2012 04:22 AM
mremillard
May 19, 2011 01:10 PM
JimC64
Jun 10, 2010 07:41 AM
daddylogan
XJ40 ( XJ81 )
Oct 8, 2009 05:19 PM
