XJS Anti-lock brake system check....
So I'm driving my '88 XJS down the black-top pavement road at about 40 mph and a young lady pulls right out in front of me (seemed like she came from nowhere). I slammed on the brakes and I ended up with 4 good long skid marks on the pavement from the skid, I closely missing her as my car came to a stop while she drove off with BIG scared eyes. Perhaps my ABS system was working. How would I know because it all happened so fast? Can anyone here comment on some kind of way that I can verify that my ABS system is actually working properly? .....thanks, Mike.
There are no lights on and the pedal feels solid. The brakes were all replaced just before I got the car last February. I'm not sure how thoroughly the brakes were done but I have seen new pads all the way around at least. I haven't tried the third test but will try it to see if I hear anything running. Thanks for the imput! .......Mike.
When you turn the ignition on the ABS pump should run and the ABS and Brake lights come on for about 30-60 seconds then go out. Does this happen?
The best way to test the ABS is on a loose surface like a gravel road, ABS does not activate under 10km/h
Are you sure you have anti-lock brakes?
For the USA market anti-lock brakes were a feature introduced on *1989* model year cars
Wow, all good things to check out here on mine. My car shows the build date of 7/'87 and is listed as a MY '88. Maybe it doesn't have ABS. If that's correct then maybe it's working as it should. According to my glove box book it addresses info as if I have ABS. I'll check the book closer to see if it is addressing it as an option. I guess I can check the service manual and see if I can find some plumbing under the bonnet that looks like ABS stuff. Where should it be located? What I see on the firewall where the booster and cylinder are that there isn't anything else visible from the top side that would indicate the extra hardware but maybe it's under the car. ......Thanks, Mike.
No, mine looks nothing like that. So maybe I don't have ABS brakes! In my mind that would be a good thing since it's one more thing to have to deal with if there are problems. I'm attaching a couple of pix of what I have so maybe someone can confirm it one way or the other. My other car and both trucks have ABS and I don't see the kluge of stuff associated with it in my Jag unless it's all located elsewhere.
Hey thanks Warren and the others. I am so happy that I won't have deal with that issue on this car. The other issues are fun enough! Dang, I love this car. Now I'm working on turning my upside down Cruise Control installation right side up and another item on the long list will be done, assuming it works. Still a number of issues left but I'm getting there. .................thanks to all. ...........Mike.
Snookfever
Oct 1, 2018 07:48 AM
Palmero
XJ40 ( XJ81 )
Jan 23, 2013 11:56 AM
JaguarXJ6
XJ40 ( XJ81 )
Aug 26, 2012 07:58 AM
