XJS Boot/Trunk Seal
Old Dec 23, 2022 | 08:25 AM
getaway's Avatar
Default XJS Boot/Trunk Seal
I just went to replace the seal and noticed that the join was at the top. It seemed to me it would make more sense to have the join at the bottom, with water not going directly on it, that maybe someone previously fitted it wrong.
I then had a look at my S3 Daimler and that's the same, join at the top - anyone know if it's like this is for any reason please?
Old Dec 23, 2022 | 11:12 AM
equiprx's Avatar
No reason that I can imagine, but I do recall that my 94 was also joined at the top.
Old Dec 23, 2022 | 04:38 PM
sanchez's Avatar
In both my '85 XJ6 and '88 XJS the trunk seal joints were at the bottom centered at the trunk latch. Each end was connected together with something that looks like a piece of hose.
Old Dec 24, 2022 | 03:46 AM
Steve M's Avatar
Mine was joined at the top but when I replaced it I put the join at the bottom, made more sense to me.
Old Dec 24, 2022 | 06:57 AM
getaway's Avatar
Yes, the new seal had the little bit of hose in one end. Maybe it was just down to who happened to be fitting it at the factory?
Old Dec 25, 2022 | 05:15 PM
mghirsch's Avatar
I think seal should have the joint at the top. When water flows into the channel by the seal, it flows down. The opening of the seal, if at the bottom would let water into the boot.
Old Dec 25, 2022 | 06:51 PM
equiprx's Avatar
That's why the seam should be sealed and reinforced with the center hose.
Old Dec 26, 2022 | 03:26 AM
Steve M's Avatar
But as you corner, any water in the channel will slide left to right and pass over the gap, and get into the boot.
If the split is at the bottom then the water would have to flow uphill to get in.
Old Dec 26, 2022 | 06:18 AM
getaway's Avatar
There was a bit of tape covering the joint - any idea what should be used for this?
Old Dec 26, 2022 | 06:40 AM
leo_denmark's Avatar
I just glued the joint. No more speculations…
Old Dec 26, 2022 | 12:56 PM
Steve M's Avatar
That's just cheating and against the spirit of everything we stand for.
If you actually fix something, what are we going to talk about?
Old Dec 27, 2022 | 05:54 AM
getaway's Avatar
Old Dec 27, 2022 | 05:55 AM
getaway's Avatar
Good idea - I will superglue it.
Old Dec 27, 2022 | 12:16 PM
equiprx's Avatar
No!!!!!!!! Never use super glue for anything flexible!!!
It also doesn't last too long in outside environment.
Old Feb 17, 2023 | 04:23 PM
ptjs1's Avatar
I took a photo of the boot seal on my 94 Convertible.
I know the history of the car from new. The seal join is at the bottom and has never been changed. It also seems the seal was closed and sealed at the factory with some sort of sealant or rubber vulcanising.
Paul
Bob Hornby
Sep 13, 2021 02:34 PM
ArtoR
Apr 3, 2021 07:29 PM
Kendojag
Aug 18, 2020 11:32 PM
Man on the hill
Dec 3, 2019 11:07 AM
flyrr100
Jun 21, 2015 06:54 AM
