XJS Brake probem
Old Mar 30, 2009 | 11:07 AM
ken@britishparts.com's Avatar
Just a guess, but possibly accumulator ball....
Old May 15, 2010 | 12:42 PM
michaem101's Avatar
I'll second the accumulator ball. I currently have the same scenario and my mechanic mentioned the accumulator ball. It looks like a fairly simple installation, but you may want to do some research on the exact procedure. Please let us know how it goes.
Old May 16, 2010 | 08:18 AM
tork'd's Avatar
can anyone discribe the accumulator ball removal and replacement?
anything that should be watched for? or special procedures?
thanx don
Old May 17, 2010 | 11:46 AM
michaem101's Avatar
Get the CD ROM XJS parts & service manual on ebay - A well spent 30 bucks (doesn't work on Vista). I just got mine and would send you a print screen jpeg of the A-ball page, but I'm emailing the supplier as some items aren't opening, including the section on brakes.
Old Jun 20, 2010 | 06:24 AM
hopeitworks's Avatar
Default Couln't be easier
First, you'll need a hex bit for you ratchet - I forget what the size is. You may want to evacuate the back pressure by hitting your brake pedal 20-30x without engine on. Get a good grip on the motor because it may take some pressure and you don't want to break the mounts. Unscrew it and pop on the new one - and Bob's your uncle !!
Probably common knoweldge, but I'll say it anyways -- these things only last 10 years and the nitrogen leaks out. Be careful of cheap accumulators - the usually windup being NOS - ie, 1993 - 17 years old and probably on death's door from the second you mount it. Be sure to buy a NEW one from a reputable seller. I use Rock Auto. $165 +/-
ACDELCO P/N 25528382 (GM used the same teves system in the late 80's / early 90's)
mbergen
Oct 23, 2019 10:26 PM
Razor
Aug 28, 2019 08:34 PM
PMKimpton
Aug 3, 2019 08:22 PM
jdzubas
Oct 4, 2015 09:14 AM
Jefro
Sep 15, 2015 01:44 PM
