XJS convertible pump seal
Old Jun 24, 2021 | 09:47 AM
Rchuda's Avatar
Default XJS convertible pump seal
I am looking for step by step directions on replacing 1994 Jaguar XJS convertible pump seal. I do have a repair guide CD-ROM but it doesn't have the detail I am looking for. Also, which hydraulic fluid should I purchase here in the USA?
Old Jun 28, 2021 | 05:25 PM
kansanbrit's Avatar
I don't think you will find those instructions. Pentosin CHF 11S seems to be most popular.
Old Jun 28, 2021 | 06:43 PM
JayJagJay's Avatar
What does it look like? Same as the 1990 and around?
Old Jun 28, 2021 | 07:29 PM
Timeisrelative's Avatar
There was a decent write up either on here or the jaglovers forum, but I think it's on here. It can be a little bit fiddly, but really not that hard once you get into it.
Old Jun 29, 2021 | 06:50 AM
JayJagJay's Avatar
Default This is all I got
I'm sorry, when I did mine in the earliest days of working on this thing, I didn't know the value of a photo record. I only have one. Thing is, you pretty much have to disassemble the whole thing (from memory) and get to the place where you find the shaft, coming from the motor on one end, thru the central assembly (the section with the hoes attached) out and thru to the mechanicals of the pump and into the tank side. See photo. The photo, I believe, is on the side that the tank is secured to a face plate that isn't captured in this photo... You may be able to find an exploded view of this pump searching online.
That central semi round is the pump shaft. Mind those bearings, the gears, note orientation etc. Work on a towel as there will be fluid and, more importantly, the two little very specific bearings will want to take a trip into the great unknown. The seal (again from memory) is exact and is sandwiched between two EXACTing flat and smooth washers on the opposite side/face of what is seen in this picture. Get the top washer off, old seal out, leave one washer - the "bottom" in place (unless you want to clean and polish) and then put everything back together. The pressure exerted by the bolts that secure everything (again from memory) will slightly pinch and flatten the rubber seal and BAM! Sealed unit.
Now, I'm terrrrrible with small fiddly things and if I could do it (with my own mishaps cause by being a brute) anyone can.
Your washers and the seal will be found on the back side (if I'm not mistaken) of this assembly...
Old Jun 29, 2021 | 07:31 AM
JayJagJay's Avatar
This may help.
Old Jun 29, 2021 | 11:03 AM
coindigger's Avatar
Hey,
I´m not sure whether my report helps...?
https://www.jaguar-forum.de/forum/viewtopic.php?t=60518
Tom
Old Jun 29, 2021 | 05:54 PM
JayJagJay's Avatar
Originally Posted by coindigger
Hey,
Tom
That's PERFECT! What an amazing thread.
Thanks for this!
Old Jan 25, 2023 | 11:15 AM
Vee's Avatar
Vee
Hey,
Tom
This certainly illustrates the entire process. Thank you so much for sharing this!
After reading other narratives, these pictures, and well as your narrative is a big help.
Thanks again for posting!
Rchuda
May 28, 2021 06:24 AM
Zolomoro
US Southern Midwest
Aug 17, 2020 10:53 AM
ericjansen
May 7, 2019 06:42 AM
hottrodd
Feb 12, 2011 09:18 AM
