XJS Gearbox in limp mode and four fault codes
Pim,
40ma is just about ok.
Some cars will even struggle to turn over at 12.02v. You really need to have at least 12.5v.
Disconnect your battery and charge it to a minimum stable voltage of 12.75v. Don't rely on the measurement immediately after disconnecting the charger. You need to leave it for at least 5 mins and then measure it. Now leave it disconnected and measure it after 24 hours. Then do the same test with it connected and see the difference of a 24hr drain with it connected vs a 24hr drain with it disconnected.
Paul
Paul
just giving an update; car is doing fine, no more gearbox warning lights... I'm happy , and it starts to feel reliable now, its a treat to drive it, although still a bit frustrating I couldn't really say what the exact solution was... anyway..
thanx again
Pim
thanx again
Pim
