XJS HE Distributor timing eccentric bolt
Old Jul 22, 2021 | 05:32 PM
Jacko5711's Avatar
Default XJS HE Distributor timing eccentric bolt
Re: 1986 XJS 5,3l V12 HE
On the side of the distributor is an ignition timing eccentric bolt. The eccentric pin has gone missing allowing the dissy to turn at will, Does anyone know where a spare or new part can be obtained? Tks
Old Jul 22, 2021 | 09:48 PM
Your in OZ?
I made a pin for the PreHE, never found the missing pin, long gone before i got the car.
Memory???? HAHAHA.
I found a bolt, the right diam, cut it, so I used the plain shank, JJB Weld and tapped it into the hole, which was a bit iffy, so I suspect some clown tried to adjust it too far, and broke it.
It was OK, and once I set that timing, 1992, never touched it to this day.
Old Jul 24, 2021 | 02:50 AM
rgp's Avatar
rgp
Originally Posted by Grant Francis
Your in OZ?
Memory???? HAHAHA.
Where is this bolt situated please?
Old Jul 24, 2021 | 04:04 AM
Greg in France's Avatar
If you look at the Lucas dizzy, in the car, you will see an adjuster screw at the edge of the metal body part, just below the cap, in about the 11 o clock position (where straight ahead is 12). Turning the screw allows timing adjustment
The attached pic is of a striped down dizzy, but the slot into which the screw goes is at the end of the blue line.
Old Jul 24, 2021 | 04:07 AM
Look down the front face of the diistributor, looking back at you is a largish scewdriver "slot", Thats it.
The underside has a cam and pin arrangement for the fine timing adjustment of the upper section of the distributor.
It has a lock nut, 13mm (AKA 1.2" a/f).
Rarely played with.
It allows a few degrees of adjustment, the numbers fail me now.
If it is Man Handle when it gets to the end of its travel, that pin will suffer.
Old Jul 25, 2021 | 01:21 AM
Jacko5711's Avatar
tks: BTW it looks like you can disassemble the unit still in the car - what are the procedures????
Old Jul 31, 2021 | 05:21 AM
BradsCat's Avatar
I have one
Fingers13
Feb 6, 2021 12:10 PM
Japthug
Oct 22, 2017 06:24 AM
ProXJS
Apr 20, 2017 06:02 PM
adenshillito
Jun 22, 2015 06:44 AM
aaronjohnson3944
Oct 28, 2010 08:16 PM
