XJS Power Steering Vibration
Old Jul 19, 2015 | 10:48 AM
mikebaker3's Avatar
Default XJS Power Steering Vibration
I'm getting a vibration back through the steering wheel that feels a lot like a drive shaft or axle U-Joint going bad. Vibration is not continuous.
Pump has the correct amount of Dextron III in it.
Any ideas? If a bearing were going bad, wouldn't the Garlock seal be leaking due to radial play in the bearing?
Old Jul 19, 2015 | 04:43 PM
Ltd's Avatar
Ltd
Default Vibration
Mike,
Have you checked the front wheel bearings? Another probability are worn front stub axles. Also a wheel out of balance. Steering rack bushings?
Old Jul 25, 2015 | 05:05 PM
mikebaker3's Avatar
Default Was the Wheel Bearings
It was the wheel bearings. Right side had about .011 play. Left side was within limits at .003.
Photos show spalling of rollers and the conical races. Left side inner bearing had no indication of damage, but I replaced it anyway. After replacing bearings, vibration was gone.
Attached Thumbnails XJS Power Steering Vibration-dsc00803.jpg   XJS Power Steering Vibration-dsc00804.jpg
mbergen
Oct 23, 2019 10:26 PM
Dicque
Sep 19, 2015 12:53 PM
hen555
Sep 7, 2015 11:13 PM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
