XJS THM400 transmission kickdown switch modification.
Old Mar 10, 2021 | 02:31 PM
Dleit53's Avatar
Default XJS THM400 transmission kickdown switch modification.
I did a little modification to my transmission kickdown switch and I am pretty happy with the results. Instead of the switch not activating until after you reach wide open throttle, it now activated at about 3/4 throttle. I am pretty happy with the results. All I had to do was to move the switch from the bottom of the plate on the throttle cable, to the top of the plate, drill 2 new holes, and adjust the switch, and mounting plate to contact the throttle rod.
Old Mar 10, 2021 | 02:38 PM
Dleit53's Avatar
I am also running this vacuum modulator, which is a little more performance oriented. Shifts are a little hard when cold but quite nice when warmed up a little bit.
Amazon Amazon
Old Mar 10, 2021 | 07:30 PM
Doug's Avatar
Kickdown mod: clever!
I've recently changed my KD system (again). I post pics sometime soon
JayJagJay
Sep 25, 2020 01:02 PM
tdshepard
May 22, 2017 04:01 PM
bullittandy
Sep 8, 2016 02:31 PM
darrhel
May 10, 2015 09:32 PM
i_like_ike
Mar 20, 2009 05:33 AM
