XJS V12 kickdown switch
Old Apr 21, 2022 | 06:27 PM
  #41
Hwoody4136's Avatar
Thank you jag. I’ll inspect the regulator closely.
Old Apr 23, 2022 | 01:19 AM
  #42
Lachy's Avatar
Greg I just did the same thing as you. Great idea.
Seemed the easiest at the time and I wanted to use the same micro switch. I can't find one that has a steel pin and proper size terminals. Ie a chunky one for under bonnet use. I have bent the arm a bit so I get throttle enrichment then kick down. Like click then click and I like it so you can adjust when the kickdown come in. See how it goes. Love these little things that make a difference.
Old Apr 23, 2022 | 01:26 AM
  #43
Greg in France's Avatar
So is the rod activating your switch?
Old Apr 23, 2022 | 01:48 AM
  #44
Lachy's Avatar
Yes the rod activates the switch. Simple flip of the switch, position, drill two holes and button up. Took 20 minutes and it's adjustable which is what I was after.
Old Apr 23, 2022 | 07:17 AM
  #45
Hwoody4136's Avatar
I found exact replacement pen part from terrysjag.com.
Old Apr 23, 2022 | 12:32 PM
  #46
Hwoody4136's Avatar
Thanks for all the help! Purring like a cat! Now, how do you free up the kick down part of the original cable? I’m a bit of a purest and would like it. To work again. 🤷‍♂️
Old Apr 23, 2022 | 01:40 PM
  #47
Doug's Avatar
It's probably just seized up. I'd try your favorite penetrating oil and see what happens
Old Apr 23, 2022 | 04:13 PM
  #48
Hwoody4136's Avatar
Thanks. That’s what we’re doing. I’ll keep all posted
Doug
Apr 22, 2021 06:08 PM
Dania Bar
May 21, 2017 07:57 AM
darrhel
May 10, 2015 09:32 PM
Darel
Oct 27, 2011 12:49 PM
i_like_ike
Mar 20, 2009 05:33 AM
