XJS V12 Marelli Engine Cuts Out at 7000 RPM in 2nd Gear
Old Aug 24, 2020 | 11:21 AM
orangeblossom's Avatar
Default XJS V12 Marelli Engine Cuts Out at 7000 RPM in 2nd Gear
Hi Guys
Got an unusual problem (at least for me)
Everything's is ok when I am in drive but when accelerating in 2nd at around 7,000 RPM the Engine seems to cut out and pull up but if I put her back in drive then She runs as normal
Any Ideas?
Old Aug 24, 2020 | 11:33 AM
Greg in France's Avatar
7,000 rpm? not 5,000?
Greg
Old Aug 24, 2020 | 11:49 AM
Hi Greg
That's a little bit too 'Cryptic' for me, maybe it was 5,000?
Old Aug 24, 2020 | 02:56 PM
VancouverXJ6's Avatar
It should forcibly shift at around 5000 right? Regardless of gear. When you say cut out like...power off done goodnight? Or just nope wont go past 5xxx revs
Old Aug 24, 2020 | 03:00 PM
The GM400 will automatically shift into second from first, even if first is selected using the stick, at about 5,400 rpm. If second is held on the stick the box will never go into third.
OB, What i meant was, did you really mean 7,000 rpm? I would have thought 5,000 was more like it!
Old Aug 24, 2020 | 03:36 PM
Hi Greg
Perhaps I didn't explain that very well
When the Car is in drive She runs perfect regardless of top speed but there are some very twisty roads where I like to Manually put and leave the Shifter in (2) instead of (D) where regardless of the gear changes that happen inside the gearbox, when the Shifter is moved Manually from (D) to (2) and left in (2)
When the Revs have gone up to around 7,000 rpm
That is when the Engine starts to Stutter and Shake like it is misfiring and that is when I put her back in (D) and then continue the rest of the journey in (D)
This has only recently started to happen, as before I could drive around with the Shifter in (2) for as longs as I wanted without any problem
Old Aug 24, 2020 | 03:44 PM
Hi Vancouver
When the Shifter is in (2) and left in (2) the engine starts to Stutter and Shake at around 7,000 rpm which has never happened before, so not sure what could be wrong
Where it really sounds just as if it is about to Stall, so at that point I change into drive to avoid any damage
Old Aug 24, 2020 | 05:04 PM
jag-reflex's Avatar
Failing coil?
Some Day, Some Day's Avatar
I'm slightly confused as well. On my car at least, 7,000 rpm is the absolute top, well into the red zone (starts at 6500 rpm). Even in second I've never been able to get close before running out of road on any twisties. On the straight, she'd be doing instant-licence-losing speeds at 7,000 rpm, assuming I ever got that high. I have to be really pushing her to break 5,000.
Reference thread HERE.
Old Aug 24, 2020 | 05:09 PM
Jagboi64's Avatar
I'm a bit surprised the automatic is still holding together at 7000 rpm. You could be getting valve float at those revs too. Given how it's well past the red line I'd not be wanting to explore that part of the rev band.
Old Aug 24, 2020 | 05:43 PM
Hi Guys
I got that completely wrong!
Just did another Test Drive and in position (2) on the Shifter, the Engine starts to Stutter and Cut out around 4000 rpm
(Jagboi) I've always kept well out of the Redband
But still very strange this should happen, as that's never happened before
Old Aug 24, 2020 | 05:58 PM
Jagboi64's Avatar
4000 rpm makes a big difference. Then I'd start to suspect something in the ignition, likely a coil.
Try the same experiment in first gear and see if you have the same misfire at 4000rpm in first. Also see if you can vary the load while holding the revs in the band you were experiencing the stutter, that will help determine if it's spark or fuel.
Old Aug 24, 2020 | 06:24 PM
Hi Jagboi
Great idea!
Maybe I've got a Blocked Filter
The Cutting out and Stuttering, seems to happen more on very hot days, if that's any clue?
Old Aug 24, 2020 | 06:48 PM
Jagboi64's Avatar
That suggests electrical, the coils performance degrades in heat. I'd replace the coils and see what happens. Check your HT leads too. Any idea how old they are?
Old Aug 24, 2020 | 07:21 PM
Hi Jagboi
You better sit down for this
The Coils and Leads are Original 30 Years Old!
Old Aug 24, 2020 | 08:08 PM
Jagboi64's Avatar
I don't think they owe you anything now, it's time for an ignition overhaul. Do the lot while you are there: coils, plugs, rotor, cap and coils. Don't skimp either, buy the good stuff.
My coils lasted 75,000 miles before I could feel a misfire.
Old Aug 24, 2020 | 11:54 PM
Hi Jagboi
I'm suprised your car hasn't casually caught fire.
full overhaul nowwwwwwwww.
I recently picked up some 10mm leads from a UK supplier they seem nice, havnt installed yet. Like some people here will suggest getting thick magnecor or other heavy duty racing spec cables will last a life time. If u need marelli amps I can give you the #part number for exact equivelent parts... It beats the $450/ea for 'original' vs these which were 30ish each?
Old Aug 24, 2020 | 11:55 PM
garethashenden's Avatar
This reminds me of the description of the effects of an Italian tune up in Kirby Palm's book. Obviously, make sure the car is in good condition before trying this, but it could explain what you experienced.
People think I’m makin’ this stuff up about the Italian Tune-Up. Bill de Creeft provides a quote from a British car magazine after the HE engine came out: “...if one runs the car for not less than a working week of relatively gentle driving, typically commuting with no longer journeys between, then, once properly warm, accelerates flat out, the engine goes through a period between 4500 and 5000 rpm of loud detonation accompanied by pale but noticeable exhaust smoke. You learn, after the first rather frightening occasion, to keep your foot down regardless, to accelerate through the knocking which, together with the smoke, stops and doesn't return until after the next period of town running. Jaguar,and Michael May, say that in gentle driving or with a lot of cold starts and short journeys combustion deposits build up in the head and on the valves. On hard acceleration these deposits heat up and burn, causing detonation but clearing, as they burn off into smoke. Jaguar says that in tests they conducted before the engine's launch (in July'81) in which such deposit-induced detonation was sustained artificially for long periods of hard running, showed no sign of piston or head damage.”
Old Aug 25, 2020 | 05:17 AM
Hi garethashenden
That description sounds exactly like what I am experiencing with loud detonation noises in that rev range although it also feels like my Car is misfiring in between 4000-5000 rpm but only when accelerating hard in (2) on the Shifter
It never happens when the Shifter is in (D) but then of course the revs are that much lower
Old Aug 25, 2020 | 05:20 AM
Hi VancouverXJ6
New Coils sounds a good idea, please could you give me the part numbers for those Marelli equivalent Coils
Alex
