"Check Fuel Filler Cap"
Old Apr 5, 2008 | 04:17 PM
GhostriderXKR08's Avatar
Default "Check Fuel Filler Cap"
Go this yellow triangle warning today. Opened the cap and made sure it's tightenedbut itstill displays on the dash. Anyone get this warning before? Bad Cap? Just curious before I bring it in on Monday. TIA!
Old Apr 5, 2008 | 07:13 PM
FactoryJaguarTech's Avatar
Default RE: "Check Fuel Filler Cap"
Likely your dmtl pump is not sealing. If your dealer is any good they will run evap self test watch it fail then clamp off hose to pump. It will then pass. They should then replace the dmtl pump and canister assembley.
Old Mar 30, 2019 | 09:04 PM
kenmicn's Avatar
Thanks; I am thinking the DTML pump the techs replaced needs to be replaced again or repair a hose....?
I will definitely follow-up.... Thank you again for your reply.
Old Mar 31, 2019 | 12:51 PM
JagV8's Avatar
11yr old thread - now that's resurrection!
Old Apr 1, 2019 | 03:36 AM
............... and the OP has a 2009 XF Supercharged so it's also transmutation.
Old Apr 2, 2019 | 10:41 PM
riverman's Avatar
Mine was the cap about 2 years ago.
Sqeeter91
Sep 4, 2013 10:38 AM
YYZ
Aug 13, 2013 10:59 PM
Perse1
May 5, 2013 02:17 PM
Earnest
Dec 9, 2009 07:22 PM
stevef
Jul 16, 2008 12:40 PM
