07 supercharger vs 04 supercharger whine
Old May 5, 2021 | 09:44 AM
XKRfangs's Avatar
Default 07 supercharger vs 04 supercharger whine
I just picked up an 04 xjr for everyday and noticed the supercharger whine is much more noticeable and louder than my 07 xkr. I think the only engine differences are the addition of vvt (correct me if I'm wrong), are the superchargers the same ? My xjr does have an aftermarket intake installed, maybe the additional noise is attributed to intake ? Thanks
Old May 5, 2021 | 09:48 AM
jahummer's Avatar
Jaguar put more effort into whine suppression in later models. Some of this can be undone to get the whine back, if desired.
Old May 5, 2021 | 09:50 AM
XKRfangs's Avatar
what would you recommend to get a similar sound ? Does the intake need to be changed ?
Old May 5, 2021 | 09:52 AM
jahummer's Avatar
That would make the most significant change. The X150 intakes have numerous resonators which mute the whine. Also remove the engine cover.
Old May 5, 2021 | 09:54 AM
XKRfangs's Avatar
ok great, thanks . . .maybe a few ponies could be picked up along with the sound . . .is the actual charger the same ?
Old May 7, 2021 | 02:12 PM
AlexJag's Avatar
Sponsor
This will help quite a bit ! Factory paper best filtration but 40% larger filter area. No codes of any kinds . Supercharger noise will be louder
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old May 7, 2021 | 02:58 PM
XKRfangs's Avatar
looks like a nice setup, who makes the intakes?
TheDraconicWolf
Jul 29, 2019 10:12 AM
VPinGA
Mar 13, 2018 08:46 AM
Mike:P
Nov 26, 2014 01:02 AM
Mdm
Apr 27, 2012 09:04 AM
vincent661983
Nov 3, 2010 04:05 PM
