07 XKR traction control
Old Jan 23, 2015 | 10:41 AM
1 of 19's Avatar
Default 07 XKR traction control
I've have come to realize traction control is my friend, especially since I spooled up $1,400.00 worth of Bridgestone Blizzaks. However when I put the Pirellis back on this spring I would like to have the option to turn my traction control off if I so desire. My traction control is either on or if I disengage just sort of off. How do I turn off completely the manual seems vague on this. Thank you in advance for your time.
Old Jan 23, 2015 | 12:35 PM
andys-GR's Avatar
Not sure on the earlier cars but on my 2011 press and hold the DSC for 10 seconds and it will show TRAC OFF
Old Jan 23, 2015 | 01:48 PM
Cee Jay's Avatar
DSC OFF, DYNAMIC ON, and SPORT are about the only options to choose. I suppose there is a fuze somewhere you could pull, but I don't know offhand which one.
Old Jan 23, 2015 | 02:33 PM
andys-GR's Avatar
It must be possible. In the first top gear / Jeremy Clarkson test of the 4.2 XKR he clearly had it turned off. Seems unlikely he would have pulled the fuse with out complaining about it it?
Old Jan 23, 2015 | 02:38 PM
Cee Jay's Avatar
Of course, he said it was powersliding at 110 MPH. I've not got a place to give that a try as there are no unused runways near me. Dangnabbit.
Old Jan 23, 2015 | 03:42 PM
u102768's Avatar
It is. Your first post does indeed apply to the earlier cars as well.
Old Jan 23, 2015 | 04:47 PM
andys-GR's Avatar
We all need a un used air port, I think Jaguar should give access to one with every car
Old Jan 25, 2015 | 06:12 PM
Timmah!'s Avatar
The manual does not say anything about DSC being able to be turned off. Maybe the legal department over-ruled that. But, if you press and hold the traction control button for 10 seconds, you will see DSC OFF displayed center dash. Be warned - with DSC off, she can get out of hand quickly. It's like when you have a sexy librarian type girlfriend - and then her evil twin shows up. Really fun, kind of scary and you can get in trouble really quick... Don't ask...
Old Jan 25, 2015 | 10:59 PM
DpezXK8's Avatar
Andy and timmah! are correct.
It's on page 166 of the manual.
Press and hold the DSC switch for less than three seconds cycles between Trac DSC or DSC On.
Press and hold DSC switch for more than three seconds to turn off.
Message center will temporarily display DSC OFF and a warning chime will sound.
The warning light on the instrument cluster will illuminate.
Press and release DSC switch to turn back on.
Haven't tried it without traction yet, waiting for spring and my 20" Summer tires back on the car.
Old Jan 26, 2015 | 04:00 PM
guy's Avatar
guy
I enjoy the car in the winter... and as I find DSC 'counter-intuitive' and annoying, I press the button for 10s, too. Everytime.
Old Jan 26, 2015 | 04:27 PM
andys-GR's Avatar
I haven't tried to reef on it with trac Off but it seems pretty well behaved, but its much better when the diff is functioning normally
Its a lot of torque if want to be stupid you can! I did standing start donuts on dry tarmac no problem, huge amount of smoke, if I'd done more than 4 I think the local fire dept might have shown up
Old Jan 26, 2015 | 05:07 PM
DpezXK8's Avatar
I'll have to give it a shot on the way home, Just got a lite dusting so time to have a little fun, traffic permitting of course
Old Jan 26, 2015 | 06:23 PM
amcdonal86's Avatar
The thing I'm wondering is whether or not turning off traction/DSC cuts off the ABS as well.
Old Jan 26, 2015 | 06:51 PM
Timmah!'s Avatar
ABS is always on as long as your ABS is functional.
Old Jan 26, 2015 | 10:09 PM
DpezXK8's Avatar
That was fun but the manual is wrong about 3 seconds.
I had to hold it down for at least 10.
Old Jan 27, 2015 | 12:58 AM
Ngarara's Avatar
It might depend on the age of the car. Here's what the later user manuals say:
SWITCHING DSC OFF
Press and hold the DSC switch for more than 10 seconds (3 seconds for XKRS vehicles).
The R-S mentioned is the 5.0 model, not the 2008. For TracDSC:
SWITCHING BETWEEN DSC AND TRAC DSC
Press and hold the DSC switch for less than 10 seconds (3 seconds for XKRS vehicles).
I don't have a earlier manual than 2009, and that also states 10s. However, there's a note in the Jag Chassis Systems manual that says:
NOTE: On early vehicles, the press-and-hold requirement was 3 seconds.
So, perhaps it's 3s on a 2007, for instance.
TracDSC increases the thresholds before traction & yaw control kick in, DSC Off disables both features. However, I believe that other stability-control features, like Cornering Brake Control, Electronic Brake Force Distribution, Engine Drag-Torque Control and Understeer Control stay active - the workshop manual doesn't say they're disabled when DSC is off.
Old Jan 27, 2015 | 10:58 AM
DpezXK8's Avatar
Mine is the original 07 manual that came with the car and it does say 3s but it took 10s or more for the DSC to turn off.
Maybe the XKR or XKRS is different but the safest bet it just hold it down till the information display says DSF OFF and the little car with the skid mark lights up in the speedo.
Old Jan 27, 2015 | 01:15 PM
guy's Avatar
guy
Precisely! Thanks for the smile!
Old Jan 27, 2015 | 01:21 PM
guy's Avatar
guy
Ive often wondered this myself. The car is so well behaved and balanced, even when you don't expect it to be. There's this hard right curve on the 4 lane that rumour has I've taken far to fast in the snowy weather... sideways. And the car was right in the middle of the lane the entire way through. Granted the right foot was a little heavy all the way through which may have helped but it was clear the wheel was turned left, for the car to go right. And coming out of the corner was without excitement... someone, something was helping.
Old Jan 27, 2015 | 01:41 PM
jagtoes's Avatar
I think this is with the DSC turned off.
