2007 XK headliner restoration
Old Apr 25, 2022 | 06:09 PM
SiPhil's Avatar
Default 2007 XK headliner restoration
New member here, in last summers westcoast heat dome a portion of my 2007 XK's headliner cloth let go & sagged.
Does anyone have procedural advice or a shop experience with a 2007 - 2014 XK/XKR headliner restoration?
Wondering if the windshield needs removal prior to removal of the headliner board, if affirmative this opens a can of worms with possible breakage of the laminated/heated windscreen circuit wiring, therefore a possible new windscreen to add.
Thanks in advance for comments
Popular Reply
Apr 26, 2022, 10:55 AM
ExKayRick's Avatar
ExKayRick
Default Headliner: Been There Done That
SiPhil:
My headliner failed in October 2021, after a bout of unseasonably warm weather in San Diego CA.
Replacing the headliner was the first project I performed on my 2008 XKR. If I can do it, you can do it!
Definitely review the Tberg thread suggested by Sean W.
Tberg and I spoke prior to the project and he kindly shared his textile knowledge and advice. I found the exact color match of Passion Suede material and California compliant headliner adhesive from a local auto/furniture upholstery shop, UFO, Upholstrey Factory Outlet in National City Ca.
I did take pictures and I have uploaded them to an album and I will try to attach to this response.
I am no expert having only done one headliner, but my project looks factory gorgeous and hasn't fallen yet! Anyone who needs help/advice is welcome to DM or email me I learned a few tricks, (i.e. bleed through)
Rick Dumas
savoryleyef@gmail.com
Headliner Trim Piece- Note the angle of the black post below my index and middle finger. When removing, pull downward toward the center console, NOT downward toward the door.
View of C Pillar headliner trim molding detached (enough to remove headliner board).
View from open back hatch, on the left the C-pillar, on the right the back of the headliner board loosened.
inside view of headliner board before exiting out passenger side.
This if the way I removed the headliner board; lowered passenger window, open door.
top view of sagged headliner board
Other side of the headliner board.
Headliner board removed
Healiner removed looking toward hatch opening
Slowly peeled back old headliner material, exposing the faulty rotted foam.
In the process of removing rotted foam
Tools used to remove the rotten foam.
Old Apr 25, 2022 | 07:13 PM
Sean W's Avatar
Hi and welcome. No need to remove the windshield. Give this a read:
https://www.jaguarforums.com/forum/x...dliner-204416/
Old Apr 26, 2022 | 10:55 AM
ExKayRick's Avatar
SiPhil:
Rick Dumas
Old Apr 26, 2022 | 04:00 PM
SDCR_XK's Avatar
Very nice pictorial of your headliner restoration.
btw, a while ago, I found something online, which shows how to remove the rear quarter window. The video showed that the quarter window, is relatively steady to remove. Only held in place by one bolt or fastener. I suspect that, with that window removed, getting the headliner in and out of the interior, would be easier. Thoughts?
Old Apr 27, 2022 | 08:39 AM
ExKayRick's Avatar
Nice to know the window is easy to remove, but it's not difficult to maneuver the headliner in and out. Clean hands, with slow and careful adjustments, and balance does it. Having someone around to assist in the extraction would have been nice. It's like exiting the passenger side with a huge takeout pizza.
Old Apr 29, 2022 | 12:37 AM
SiPhil's Avatar
Thanks everyone for your replies and helpful advice, much appreciated!
Old Apr 30, 2022 | 09:28 AM
Sean W's Avatar
@GGG can you please add this to the DIY section?
Old Apr 30, 2022 | 01:25 PM
DONE.
See Section 7 - INTERIOR:
https://www.jaguarforums.com/forum/x...enance-227403/
Old Apr 30, 2022 | 09:14 PM
Tracee's Avatar
When dealing with my sagging headliner, I found the original foam backing had turned to mush, causing the fabric to lose adhesion. A much neater way to remove this residue was to use a paint scraper to push the mess off the board. Less clean-up, also...
Old Jul 27, 2022 | 06:05 PM
McJag222's Avatar
Thanks for posting the pics and explanation Tracee. I might attempt this myself.
Old Jul 28, 2022 | 08:20 AM
shemp's Avatar
I had mine done at a headliner specialty shop. They did not remove any windows. 2010 XK coupe.
Old May 25, 2025 | 06:22 PM
Sean W's Avatar
@ExKayRick I know this post is a bit old but just realized you never posted a pic of the finished product. Will you please?
Old May 26, 2025 | 08:32 AM
luv2fly's Avatar
Don't know where you are, but I was just quoted $275 to replace my headliner. They do it all. Told me not to touch it. 3Rs Trim Shop, Easley, SC.
Old May 26, 2025 | 12:29 PM
ExKayRick's Avatar
Old May 26, 2025 | 06:34 PM
Cee Jay's Avatar
A bit of a pinkish hue, but that may be the lighting or camera software. Close enough, I'd say. I'd be happy with that over one falling into my face. Or even one NOT falling.
SiPhil
Canada
Apr 25, 2022 05:36 PM
slugger
Jun 15, 2021 09:34 PM
StevieG1234
Jan 11, 2020 08:36 AM
graham11
Jun 6, 2019 06:48 AM
latte8890
May 20, 2011 06:01 AM
