2007 XK timing
Old Feb 16, 2020 | 01:00 PM
Seil39's Avatar
Question 2007 XK timing
I have a 2007 XK base model does it have metal or plastic timing chain guides
Old Feb 17, 2020 | 12:00 PM
sov211's Avatar
Metal. The 4.2 litre engine has no issues in this regard...in fact almost no issues at all (apart from the thermostat housing with the integral thermostat. It should be changed as a matter of normal servicing, approximately when the transmission fluid is changed - every 50,000 miles).
Old Feb 17, 2020 | 12:21 PM
Seil39's Avatar
Red face Thanks 2007 XK
Thanks, I have already had to change the water pump and housing part of the impeller blade broken. (plastic)
Old Feb 17, 2020 | 01:52 PM
DannyJ's Avatar
What was the trigger to change the pump?
loosing coolant?
Overheating?
rez1only1
Apr 11, 2025 08:00 PM
WldCat
Aug 12, 2020 11:55 PM
robbing
Oct 1, 2015 11:24 AM
metaledge
US Western
Mar 17, 2010 05:00 PM
