2007 XK Vibration
Old Oct 30, 2015 | 09:19 AM
ed duffy's Avatar
Default 2007 XK Vibration
My low mileage '07 XK has a slight vibration when tach is at 1250 RPM. Occurs only when car is in gear, but at any speed. Any idea as to what the cause might be? Tranny? Drive shaft? ??
Old Oct 30, 2015 | 09:42 AM
FrickenJag's Avatar
Former Sponsor
Does it vibrate when stationary? If so, motor mount/tranny mount. In gear, and in motion vibration, I would suggest u-joint or tires.
Do you feel the vibration through the seat more , or the steering wheel?
Regards,
Derek Fricke
Old Oct 30, 2015 | 10:35 AM
britannia's Avatar
You sure it's not the slow speed exhaust resonance that XK's are known for?
Some dealers will add a strap to the Cats; me , just downshift or ignore............don't even notice it anymore!
Hope this helps, Adrian
Old Oct 30, 2015 | 02:29 PM
tommytess's Avatar
I Think this is quite common my 2006xk does it aswell.
Tommy
Old Oct 30, 2015 | 05:52 PM
ed duffy's Avatar
Default XK vibration at 1250 RPM
Thanks for your thoughts, guys
Slight Vibration mainly thru the accelerator and a bit thru steering wheel
No vibration when parked and engine running
No vibration when driving/coasting in neutral
Vibration only when in gear at 1250 RPM, at 20mph or 50 mph
My main concern - Is it a harmless bug? or is it something that might cause problems if not corrected? Have gotten some feedback that it is not uncommon with 2006 - 2007 XK's?
Dealer has not given me a specific idea of what is causing it - wants to get it up and check it out - but did mention something about it being an issue on 2007's. But I don't want to spend alot of money fixing something which is not a critical issue.
Appreciate any additional thoughts!
Old Oct 30, 2015 | 06:45 PM
u102768's Avatar
As mentioned by others, it sounds like you have the issue detailed in the attached TSB.
Old Oct 30, 2015 | 07:01 PM
ed duffy's Avatar
Default xk vibration
Thanks so much - looks like exactly the situation
Disappointed my dealer apparently is not aware of this
THANKS, ALL
Old Sep 23, 2024 | 05:15 PM
Zohitt's Avatar
Default Jag vibrations
good afternoon did you solve this problem?
FRGIII2014
Nov 18, 2015 04:56 PM
slownlo
Oct 27, 2015 10:26 PM
Charlroi19
Oct 27, 2015 12:11 PM
EZDriver
Oct 26, 2015 02:26 AM
