2007 xkr center console nothing working please help...
OK please just respond yes or no to whether each of these are working. They are different systems so bear with me. There is a long thin plug under the CD changer that can come loose and it's easy to miss if you don't know what you're looking for, especially if you're looking from the top. Please reply to the operational questions below and you may have to take the center stack out again and snap pics
Screen on/off button -
Flashers - working
Home button -
Radio on off button -
Radio on off volume -
Source button -
Next track -
Previous track
Eject -
Load -
Temp control Drivers side up/down -
Fan - manual -
Fan - Auto -
Temp Control Passenger side up/down -
Edit: the connector I'm referring to is under to CD stack is IP061. It's a 10 pin connector that feeds many of those functions, although it also feeds the hazards which you say is working. IP061/10 is the power feed pin on the connector. It comes from fuse 21 in the AUX junction box which also feeds the integrated audio module and information and entertainment control module .
pin 1 - ground
pin 2 -
pin 3 - MS Can Pos
pin 4 - MS Can Neg
pin 5
pin 6 - hazard
pin 7 - pad lamp airbag deactivation lamp
pin 8 - SRS Ignition
pin 9
pin10 - power from fuse
Flashers - working
Home button -
Source button -
Next track -
Previous track
Eject -
Load -
Fan - manual -
Fan - Auto -
pin 1 - ground
pin 2 -
pin 3 - MS Can Pos
pin 4 - MS Can Neg
pin 5
pin 6 - hazard
pin 9
I did pull the connector on the bottom and it does indeed have power. From your list nothing it working other than those two.
I think I will pull the stack and see if I get anything from the switches manually. Unless there is a control module for these functions..
I appreciate you input..
The panel behind the facia is flexible is it not guys? Going by memory which is never a good thing, but you want to ensure it's fitted correctly. Honestly I can't recall if I'm thinking of my XK or my wife's Cadillac. I had it improperly fitted though once while working on it and nothing worked. Took it off and refitted and it was fine. Otherwise, Jahummer has a spare he could sell as he notes. Honestly don't know what else it could be
I know of two people other than me up here, but that's it.
Naimiiy
Apr 1, 2018 05:01 AM
Carlg07
Jun 20, 2016 05:50 AM
