2007 XKR needs help
Old Nov 18, 2019 | 03:30 PM
Teddy3333's Avatar
Default 2007 XKR needs help
I'm new to the forum, I have a beautiful 2007 xkr that sounds like it's misfiring. More likely a rough idle, I have replaced the air mass sensors, the barometric pressure sensor, replaced pcv-valve, replaced all 8 spark plugs-ngk, then 8 Delphi coils. Then 4 oxygen sensors, spent over $2200.00 at a local mechanic, my car still has the check engine light on, still running lean. So frustrating, but I bought this car for $11,000.00 with 85000 miles on it. I just want to get it through Marta and get that check engine light off. Please any help anyone can give to me to get these lean codes off, without going broke, or continue to sit in the garage.
Old Nov 18, 2019 | 03:39 PM
gkubrak's Avatar
What codes are you getting? When was the last time the fuel filter was changed?
Old Nov 18, 2019 | 03:44 PM
George05's Avatar
Yes what codes ?
Old Nov 18, 2019 | 03:59 PM
Teddy3333's Avatar
I have no idea when that fuel filter was changed ? I hope the mechanic gap the spark plugs. I was told air mass sensors causing lean codes, also performed smoke test, no vacuum leaks.
Old Nov 18, 2019 | 04:05 PM
George05's Avatar
Dont worry Teddy . the guys on here are fantastic will get you running again
Old Nov 18, 2019 | 04:17 PM
Teddy3333's Avatar
Default 2007xkr misfiring
Originally Posted by George05
Yes what codes ?
I been down for a few weeks now, since I paid that large bill, but I must say I feel better just knowing there is support in getting this beautiful black on black cat running at her full potential, thank you so much for reaching out to me ! God bless you all.
Old Nov 18, 2019 | 05:12 PM
George05's Avatar
Had a look on the web. could be dirty injectors to . try some Techron a bottle in half a tank of gas see if it cleans them
Old Nov 18, 2019 | 05:27 PM
Sean W's Avatar
Not much sense in guessing here without some basic information. As previously noted, what codes are you throwing?
Old Nov 18, 2019 | 06:46 PM
guy's Avatar
guy
Old Nov 18, 2019 | 07:49 PM
Teddy3333's Avatar
I'll try that George, also I will get the exact codes that are being shown, there's been enough guessing !
Old Nov 18, 2019 | 08:45 PM
Stuart S's Avatar
Your Public Profile shows your location as US. I understand your need for privacy, but if you can be more specific and give us a city or metropolitan area, we may be able to recommend qualified local indy techs who can fix your XKR.
Old Nov 18, 2019 | 10:09 PM
Teddy3333's Avatar
Teddy here, I'm in Nashville, bought a bottle of Techron and put it the car, also got all of the codes. I'm curious, I was asked has this car been driven since the repairs? I haven't driven it far, maybe 10 miles. Someone said the car needs to be driven at least 60 miles for computer to reset itself ? Is this true? Here are the codes--( po300-thru-po308-cylinder1-thru-cylinder8-misfire detected. Next-po316-misfire detected in startup (first1000 revolutions)-po174-system too lean(bank 1)- po101-mass or -volume air flow circuit range/lerformance--po2105-throttle actuator control system-force engine shutdown.Should this car be driven on the interstate if it's misfiring ? I hope this information is helpful !
Old Nov 18, 2019 | 11:05 PM
Cee Jay's Avatar
DO NOT DRIVE IT! "Force Engine Shutdown" is a huge hint to not drive!
It sounds somewhat like a large vacuum leak. Maybe a jumped chain?
OK, now I'm just spitballing........
Old Nov 19, 2019 | 12:27 AM
Queen and Country's Avatar
You need to check the catalytic converter.
Old Nov 19, 2019 | 11:14 AM
Teddy3333's Avatar
The catalytic converter have been replaced this summer.
Old Nov 19, 2019 | 11:18 AM
With an aftermarket one?
Old Nov 19, 2019 | 11:45 AM
George05's Avatar
My moneys on injectors
Old Nov 19, 2019 | 11:46 AM
NBCat's Avatar
If DTC P0300 is present accompanied by random misfires on all cylinders, the very first thing to do is check fuel pressure. Under no circumstances is the vehicle to be operated under conditions that cause the MIL to flash as catalyst damage is occurring.
If you don't already have it, here is a link to the X150 Workshop Manual:
https://www.dropbox.com/sh/gn6p1upuh...S531fLxta?dl=0
Refer to the Manual for the fuel pressure test procedure.
What is the age of the battery? The battery must have a minimum of 12.6 volts when checked across the terminals with a voltmeter whilst the ignition is in the OFF position. If the voltage is less than 12.6 volts, charge the battery for at least 8 hours between 2 and 5 amps then perform another test. If the voltage is still less than 12.6 volts the battery must be replaced. A failing or weak battery is the often the cause of random DTCs and other electrical 'gremlins' chased on these forums.
Old Nov 19, 2019 | 12:51 PM
gkubrak's Avatar
I would agree with fuel pressure test. Replace the filter then test again. Note any difference in pressure before and after the filter change.
Since you did all that other work, the fuel system would be suspect...
Old Nov 19, 2019 | 01:25 PM
Teddy3333's Avatar
I replaced the battery 3 months ago, I will replace the fuel filter, is it safe for the car to run to circulate the injector cleaner, and if it is, how long should I let it run?
