2007 XKR start button
Old Feb 10, 2020 | 10:28 PM
rickkym's Avatar
Default 2007 XKR start button
My 2007 XKR has 60000 miles. Lately I've had to press the start button in a circle to get the car to turn on and start. So how hard is it to pull the red button out?
Old Feb 11, 2020 | 03:09 AM
It should be easy. I've had the trim off and that has to be the hardest part.
The single harness start switch connection is under the centre console.
Instructions for removing the veneer trim panel are available to download in the HOW TO sticky at the top of the threads. See section 5:
https://www.jaguarforums.com/forum/x...enance-227403/
The veneer trim has a moulded plastic backing.
The starter switch body will either rotate to release or have plastic tabs that keep it locked in place.
Old Feb 11, 2020 | 03:36 AM
rickkym's Avatar
Thanks got it out. The instructions say
Put in neutral
Pry gently
Hope for the best...
Old Feb 11, 2020 | 12:40 PM
rickkym's Avatar
Dang $300 USD. And that damn ASL button looks like it should work but is just different enough...
Grrrr
Old Feb 11, 2020 | 08:53 PM
jahummer's Avatar
I have an extra one here, might be able to make a deal.
Old Feb 17, 2020 | 04:47 PM
JackJohn's Avatar
When mine failed, it wouldn't shut the engine off. It would start first time every time but might take ten to fifteen pushes to get the engine to stop. Found one on Ebay and changed it in the drive way.
Old Feb 17, 2020 | 06:28 PM
TraxtarXKR's Avatar
That is 100% an eBay purchase part. Much like small plastic trim pieces and clips, these are generally in perfect condition in salvage vehicles.
Reach out to sellers that have a picture of a partially dismantled x150 as the main listing photo, or sellers that are offering parts that could really only come from a salvage vehicle. They will likely have this kind of rarely asked for part, and will be happy to sell it to you since it would have likely ended up going to the scrap yard when they finished parting out the car. I will commonly reach out to these sellers and make a bulk order of clips and random pieces that inevitably crack or break for something like $25-50, and they almost always say yes.
Example, my car was missing the seat rail cover, the mirror arm cover was loose, the engine cover clips were wrong, and 2x of the rear armrest clips snapped upon reassembly when putting the interior back together after wiring an android box and GVIF. I also lost the nuts for the cargo cover after mistakenly unscrewing the lever clips.
I made an offer of $30 for the mirror cover, seat rail cover, 8x engine cowl cover clips, 2x cargo cover clips, and 4x rear armrest snap rivets. They seller had no problem sending me those parts for the exact reasons mentioned. The local dealer wanted over $200 for those stupid parts! Online was $125 plus shipping.
Seat Track Cover - $45
Mirror Trim (Left) - $16
Mirror Trim (Right) - $16
Arm Rest Clips - $8
Engine Cowl Cover Clips - $25
Cargo Cover retaining clip - $16
I did this numerous times with my old Porsche 928 as well. Worked every time.
rexus31
Sep 25, 2019 12:27 PM
mrsclark
Nov 16, 2017 06:51 PM
Vandyone
Jun 23, 2017 07:08 PM
ShadyJC
Mar 31, 2010 01:30 PM
