2008 xk 150 gear selector problem
Old Sep 5, 2022 | 07:19 AM
Stuart xk's Avatar
Default 2008 xk 150 gear selector problem
Hi guys had a problem start yesterday where's I could not obtain drive or reverse. After several attempts moving the j gate selector up and down the car finally went into drive. I noticed that when the selector was in the drive position it seemed not to be fully engaged into a positive select position. I also noticed that the indicator light for neutral, reverse and drive only illuminated after careful selector movement. I've also noticed this morning when coming from neutral to drive, selection is only possible if you move the stick suddenly into drive and you here a click,the light then illuminates for drive and the selector is positively engaged.
Any suggestions as to what this might be would be most appreciated.
Old Sep 5, 2022 | 08:26 AM
jahummer's Avatar
This has something to do with the shifter linkage slipping, I think.
Old Sep 5, 2022 | 03:58 PM
Stuart xk's Avatar
Thumbs up
Thanks for the reply I will check and feed back
Old Sep 5, 2022 | 08:05 PM
guy's Avatar
guy
Adjustment procedures are outlines in the workshop manual. My dealer had it sorted within 30 minutes.
Spud Maat
Sep 6, 2022 10:12 PM
Biff Baxter
19
Feb 28, 2018 03:20 AM
vsol
Mar 24, 2016 07:37 AM
osagie
Oct 3, 2014 07:02 PM
drog321
Jan 26, 2008 04:00 PM
