2010-2014 Rear Active Dampers Shocks P/N
Old Sep 3, 2024 | 01:43 PM
gizzmo77's Avatar
Default 2010-2014 Rear Active Dampers Shocks P/N
Hi everyone, has anyone changed the CVD (Constantly Variable Dampers) Dampers/shocks on a XKR X150 5.0 Coupe 2010 - 2014 rear ?
I need to replace mine. What is the correct OEM P/N for this vehicle please?
I've looked at mine and they look original and are stamped Bilstein. I have a feeling C2P17674 may be correct but the info on line is really confusing and contradictory.
The Vin last 6 are: B48974
Any definitive info will be gratefully received.
Many thanks Gizzmo
Old Sep 3, 2024 | 02:15 PM
clubairth1's Avatar
Community Influencer
Hello Gizzmo! Good name for a Jag guy!
I think your close but a bit off due to your late VIN?
Here are different rear struts depending on VIN;
This is from the wonderful JPART software.
As you can see you do have the correct part number BUT for an earlier car. I "think" you need C2P22813 instead?
One thing I was not clear on is I don't see any wires attached to these struts in JPART? So I can't say if they are electronically adjustable or not? I think they must be.
Old Sep 3, 2024 | 03:29 PM
gizzmo77's Avatar
Default Fantastic
Thanks Clubairth1 👍
Old Sep 3, 2024 | 09:28 PM
Lothar52's Avatar
So… somehow I have xkrs rears on my 12
xkr hehe. They are yellow Bilsteins… my fronts are black and no obvious dot?
Old Sep 4, 2024 | 09:03 AM
clubairth1's Avatar
Yea the Bilstein colors are confusing to me? Do you go by the color or the part number or both?
etaent
XJ40 ( XJ81 )
Nov 22, 2023 02:43 PM
oxendine
Sep 25, 2022 10:03 AM
Pistnbroke
Aug 12, 2022 11:57 AM
JWestXJR2000
May 12, 2022 07:06 PM
chazaroo
Dec 31, 2009 07:24 PM
