2010 XK front brake question
Old Feb 15, 2015 | 05:11 PM
1ducatiboy's Avatar
Default 2010 XK front brake question
I'm about to do a front brake rotor and pad replacement and am needing to know what size hex wrench to us to remove the caliper bolts. A 8mm feel loose and a 10mm is to large. I've never seen a 9mm and I don't want to risk stripping the bolt head. Is there a special tool? Never had this issue with my 01 XK8.
Old Feb 15, 2015 | 06:33 PM
Ngarara's Avatar
No special tool mentioned in the workshop manual, but it doesn't specify the bolt size either.
Old Feb 20, 2015 | 08:47 PM
1ducatiboy's Avatar
Default XK front caliper removal hex tool
I determined that the hex bit (socket) needs to be a 9mm. They are not usually included with hex bit sets. However Amazon has both 3/8" and 1/2" drive hex bits for use with impact tools. These are longer than the non impact version and give the necessary clearence. I found them to be just what was needed.
D.K
Dec 10, 2023 02:05 AM
way2far
Aug 31, 2022 09:26 AM
tberg
Sep 7, 2015 07:32 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
tonydbaker
Aug 30, 2015 11:02 PM
