2011 XKR Convertible - window whistling on passenger side
Old Dec 31, 2023 | 09:42 AM
ACD's Avatar
ACD
Default 2011 XKR Convertible - window whistling on passenger side
Hi All,
New joiner to the forum, and recently purchased a beautiful 2011 XKR Convertible in the US. Had about a c. 20 year gap on Jags as I previously had XK8 Convertibles. Happy to be back on the brand.
One annoying gremlin with the car is the passenger window "whistles" at speed of c. 50mph+. Looks like its the seal between the window and the speaker on the door is loose. That's the seal on the door itself, not the car frame (its frameless round the window on the convertible).
Any idea how to fix this? I'm not very handy but figured I'd ask here before driving down to the Jaguar dealer to take a look.
Didn't see a similar thread on this but if I missed it, would appreciate the redirect.
Thanks and Happy New Year!
Old Dec 31, 2023 | 11:10 AM
Cee Jay's Avatar
A picture would help. Are you talking directly behind the tweeter triangle where it meets the glass?
Old Dec 31, 2023 | 12:53 PM
ACD's Avatar
ACD
That's fair! Pics below. Can't just push it in, so not sure if there is another trick out there.
Old Dec 31, 2023 | 01:50 PM
Stuart S's Avatar
Hi, ACD
Welcome to the Forum, and congrats on your 2011 XKR Convertible! I hope you enjoy yours as much as I enjoy mine. I see from your Public Profile that you joined today and that you don't have a signature that includes details about your and your XKR. I recommend that you read this thread and create a signature that will help us help you.
Please read the guidance for new members:
https://www.jaguarforums.com/forum/n...ned-up-241802/ ) which
Where are you located, and where has your XKR been? Your location matters, as the climate can wreak havoc on rubber parts. Your XKR is over 12 years old and the rubber seals have hardened over time. Before going to your Jaguar dealer and doing irreparable harm to your wallet, you might want to try this inexpensive DIY fix:
This product might be able to soften the trim enough to enable you to refit the glass.
DuPont Rubber Saver Gasket Seal Trim Conditioner, 25ml
https://a.co/d/3n1757b
If that doesn't soften it, you might want to try a hair dryer or heat gun, if you have one.
Here's my passenger side trim and glass.
Good luck with your repair and Happy New Year to all!
Stuart
Old Dec 31, 2023 | 02:15 PM
McJag222's Avatar
Have you tried to push it back into place with the window totally lowered?
Old Dec 31, 2023 | 04:02 PM
Woo5ie's Avatar
Have you tried resetting the window position. It’s in the manual and takes just seconds
Old Jan 1, 2024 | 03:07 PM
ACD's Avatar
ACD
Originally Posted by Stuart S
Hi, ACD
Stuart
Thanks Stuart! Think I've now done the new joiner stuff. Appreciate it!
I'm in Charlotte, NC, USA, but the car itself has been in NY and Florida before me (mainly Florida). I can imagine some heat warping the rubber.
I ordered the seal saver so will see how that goes. Really appreciate the recommendation. I also tried the ideas from the other replies but whistling still there. Hoping the seal saver is the way to go. Will report back when I know!
Old Jan 1, 2024 | 03:08 PM
ACD's Avatar
ACD
Yeah I tried that one but it still doesn't budge. Don't want to put too much force into it. I think I need to play with the seal itself.
Thanks,
Alan
Old Jan 1, 2024 | 03:09 PM
ACD's Avatar
ACD
Ah thanks for this recommendation! It didn't solve the whistling noise - the seal will need to be adjusted for that - but it did make the car quieter which suggested it needed that reset too. Thanks!
Alan
Old Jan 2, 2024 | 08:25 AM
Stuart S's Avatar
If you didn't reset the driver's side, you should do so.
Old Sep 14, 2024 | 12:51 PM
ACD's Avatar
ACD
Update here as I only recently solved the whistling noise.
The seal saver was a good recommendation generally for the seals, but didn't solve that specific problem.
Turns out the previous owner must have had some work on the passenger door / side mirror at some point and who ever did it, didn't quite put it back together properly again. Took it to my local specialist in Charlotte NC (Rock Solid Autos in Mooresville - good guys) who re-did it and voila, no more whistling.
Very happy on that front! Loving the car as I come up to a year of ownership.
(Got a wheel question but I'll post a separate thread on that)
badicedog
Jul 21, 2023 09:49 PM
Todd Wiens
Aug 26, 2021 03:53 PM
MartynL
May 7, 2021 05:12 PM
Bocabroker
Sep 26, 2017 06:11 PM
peterg19
Mar 31, 2015 08:14 PM
