2012 bluetooth adapter
Old Oct 8, 2020 | 10:37 AM
slash32487's Avatar
Default 2012 bluetooth adapter
Say im able to enable aux in engineering mode is this adapter compatible with the system? it is for the 2006-2009 xk's. if not what adapter is needed to use bluetooth on aux in xkr 2012?
Old Oct 8, 2020 | 10:55 AM
DGL's Avatar
DGL
All you need is a Bovee 1000 with cable to connect to the iphone connector in the center console. I use it with my Samsung android and it works perfect.
Old Oct 9, 2020 | 04:37 AM
Bill Mack's Avatar
You may also want to consider the Anker Soundsync. It's much less expensive than the Bovee, but it is battery-powered and needs charging.
Old Oct 9, 2020 | 10:54 AM
carealtor's Avatar
+1 for the Bovee. Had it for a few years in my 2012 and it works great.
Old Oct 9, 2020 | 11:13 AM
StiggyMac's Avatar
+1 for Bovee. Just got mine and was simple to install and use.
It will start playing the first thing in your library when your phone connects each time you get in the car, which is slightly annoying but certainly not a deal breaker for me.
Old Oct 9, 2020 | 11:15 AM
StiggyMac's Avatar
There's no 3.5mm in the 2012 from what I could see. Which is why I had to go with the Bovee.
Old Oct 9, 2020 | 01:09 PM
Bill Mack's Avatar
Good to know. Mine is a 2007 so I was not sure.
sklimii
Jul 4, 2021 09:13 PM
LegendaryV
Mar 18, 2016 07:20 PM
Unk
Mar 6, 2015 03:49 PM
Randy
Feb 28, 2014 07:10 AM
Jffcurt
Jul 4, 2013 11:32 AM
