2013 XK Convertible GPS Antenna Replacement
Old Aug 21, 2022 | 12:48 PM
sailfish's Avatar
Default 2013 XK Convertible GPS Antenna Replacement
I followed Stuart XK's great instructions for doing this on an XK150 coupe. Unfortunately, when I got to the end, removing the light strip and spoiler, all I found was the FM antenna. His pictures clearly show the same part I'm trying to replace, but it's just not there. Not sure if it's because mine is a convertible, or a newer model or something else.
Anyone have further info on this? Thanks.
Old Aug 21, 2022 | 04:31 PM
Cee Jay's Avatar
As per manual:
Old Aug 22, 2022 | 12:00 PM
sailfish's Avatar
PROBLEM RESOLVED
I found a loose wire connector inside the trunk cover; it accepted my new gps antenna. I attached it with velcro to the underside of the cover. GPS signal is fine now.
I don't know how it became this way, but there are no holes under my spoiler to accept mounting of the GPS antenna. Just the FM antenna is mounted in there.
Old Aug 22, 2022 | 02:35 PM
Cee Jay's Avatar
The antenna isn't mounted, per se. It is stuck with double-sticky tape.
Old Aug 22, 2022 | 03:00 PM
sailfish's Avatar
Default Thank yo
I appreciate your help.
Old Aug 22, 2022 | 04:02 PM
RichardS's Avatar
And a previous owner would appear to have unstuck it and thrown it away, leaving just the cable behind.
Richard
RPVillalba
Oct 1, 2024 08:43 AM
Arminius
May 8, 2022 02:28 AM
mbk2015
Jun 5, 2015 04:10 PM
ferrytrip1
Oct 6, 2013 05:50 AM
youngbozftd
Feb 10, 2010 10:49 PM
