3 times now won't start
Old Nov 3, 2025 | 07:47 AM
HealeyJag's Avatar
Default 3 times now won't start
Sigh...3 times now the car wouldn't start and lights flashed like low battery..
Jumping it didn't work..
Started pushing buttons after an hour and she finally lit up..
After reading many forums..."locked in security" mode?
New battery...
did hard reset and charging battery as we speak..
Today is my wife's birthday..she WANTED to take the XK.
Frustrating..
Old Nov 3, 2025 | 08:44 AM
Stuart S's Avatar
Press and hold the START button first, then step on the brake pedal. I know, the Owner's Handbook says otherwise, but trust me it works.
The worst thing you can do is repeatedly step on the brake pedal. "Pumping the brakes" makes it harder to start, and you may need to step on the brake pedal with both feet and all your might to get it to start.
Old Nov 3, 2025 | 09:07 AM
HealeyJag's Avatar
Have done that past month
Nope.
When hit starter button lights flash outside inside like low battery.
Dash doesn't light up
Old Nov 3, 2025 | 09:39 AM
Sean W's Avatar
You know someone is going to ask so might as well be me. What is the battery voltage reading at the terminals?
Old Nov 3, 2025 | 09:46 AM
bocatrip's Avatar
Yes, it's been discussed to nauseum, but the battery condition (regardless if it is new) MUST be eliminated before proceeding as it causes total chaos on an already fragile electrical system.
Old Nov 3, 2025 | 09:57 AM
HealeyJag's Avatar
12.7
Old Nov 3, 2025 | 09:58 AM
HealeyJag's Avatar
But if it was the battery..
Why would jumping it fail?
Old Nov 3, 2025 | 10:44 AM
HealeyJag's Avatar
Default So
in reading the other thread it is most likely
INSTRUMENT CLUSTER..
interesting statement about key fob placement.
Just want to get it started with no tow
WELL IT STARTED...
now have to figure out if it's the cluster or other issue
Old Nov 3, 2025 | 11:52 AM
Sean W's Avatar
It appears it wasn't the battery so the question is why did you try to jump it?
Next thing is to check for DTC's. Buy this. you won't regret it and don't need to be a mechanic. It will give us something to go on. Otherwise everything else is just wasted time guessing. helluva good price on it too.
Amazon Amazon
Old Nov 3, 2025 | 11:56 AM
HealeyJag's Avatar
Default Locked out
It started right up.
Key next to window on unlock
Definitely locked out...
So would the scanner point to the cluster if failing?
I am a great mechanic..on old jags!!!
All new to me..
Previous cars never had a single issue.
Hanging in there
Old Nov 3, 2025 | 12:00 PM
guy's Avatar
guy
Apologies. I'm not clear. When the voltage of the battery was read, how much time had passed since it had been connected to the charger or the boosting effort?
Old Nov 3, 2025 | 12:04 PM
HealeyJag's Avatar
Default Ratings
https://www.amazon.com/Autel-AP200-B.../dp/B07QD4GZW4
Thanks Sean.
Ratings not good..
But going to look at others
Thank you
Old Nov 3, 2025 | 12:05 PM
HealeyJag's Avatar
5 minutes
Actually 12.9
Old Nov 3, 2025 | 12:48 PM
guy's Avatar
guy
You've heard it before... readings are only useful after a significant wait time to ensure battery comes back to equalization. That's why the dealer usually keeps it overnight. After 6 hours, give it a read so that we can rule it out and get on with it.
Old Nov 3, 2025 | 02:16 PM
Sean W's Avatar
Thanks Sean.
Ratings not good..
Thank you
Understood, but I use it for a lot of things when I don't want to connect SDD. Works great for me and I know others like it too, but you need to be happy with it. The great thing about it is that it reads all codes, Body, chassis, engine etc. Make sure whatever you choose does the same.
Old Nov 4, 2025 | 10:08 AM
CA Jag's Avatar
12.7
12.7 for a n
New battery fully charged w C-Tek or similar?
Old Nov 4, 2025 | 10:53 AM
HealeyJag's Avatar
Default Charger
Originally Posted by CA Jag
12.7 for a n
nocco genius...
Old Nov 4, 2025 | 11:08 AM
CA Jag's Avatar
nocco genius...
Thanks but I'm not a genius. Not even close
Old Nov 4, 2025 | 03:30 PM
HealeyJag's Avatar
Default Modesty
Car fired right up.
After setting 24 hours..reading 12.7
Can a hard reset straighten out some things??
Old Nov 4, 2025 | 03:40 PM
wymjym's Avatar
Car fired right up.
yep but...did you have the car locked or 'unlocked'?
wj
