3rd brake light
Old Feb 14, 2025 | 12:45 PM
x9nov's Avatar
This is the back of the light (this is the old unit) the black around the torx screw is just some kind of felt washer. I believe the rusty bits that have fallen apart are called U nuts after googling, I know it’s a T20 but I don’t know what thread it would have. It’s bloody annoying, I just presumed all I would need would come with the new fitting.
Old Feb 14, 2025 | 01:53 PM
kj07xk's Avatar
Try a local auto parts store, they should have a selection of these to chose from. (You can find assortments on Amazon, but you don’t need that many.)
Old Feb 17, 2025 | 05:33 AM
x9nov's Avatar
Just a quick update, I went to Halfords of all places and bought a small packet of assorted U nuts. Used the size needed for the T20 torx bolt and everything is good. It’s just a warning for anyone else removing or changing this light fixture, my U nuts were corroded to nothing, so may be a good idea to have some of these before starting the job, they were less than a couple of quid. Thank you for all the advice 👍
Old Feb 18, 2025 | 06:17 PM
capitol1's Avatar
Hi georgekale, would you happen to know if there is a gasket that goes between the deck lid and the spoiler?? ( 08 XK coupe) Thank You!!.............r
Old Feb 18, 2025 | 08:13 PM
kj07xk's Avatar
You might want to tag @georgekale correctly to maybe get his attention, as I think he sold his X150 several years ago, and probably doesn’t keep up with this forum anymore.
(This post will have tagged him.)
Old Feb 28, 2025 | 02:35 PM
georgekale's Avatar
Right on. I sold my XKR about ten years ago.Sorry can't help you there.
Old Feb 28, 2025 | 05:25 PM
Cee Jay's Avatar
No, there is no gasket from spoiler to deck lid.
Old Apr 10, 2026 | 06:51 AM
  #28
alanroberts50's Avatar
Thank you for this! Would anyone have a pic showing the location of this diode pack on a 2013 convertible? Is it in the boot lid somewhere?
and a part number if possible?
thanks
Alan
Old May 19, 2026 | 04:45 AM
Default Another development
So after hard reset and overnight charging a couple of times with the ctek the lamp would sometimes work on startup and sometimes not so the led unit itself is ok. I have no idea if it was working while I was driving. Yesterday I got in and put my foot on the brake to start and could see it lit in the rear view mirror reflected on the wall. I kept foot on the brake while engine was running and I was preparing to move off then it (the center brake light) just went out for no apparent reason. Is there some sort of safety relay similar to if you hold the window switches for too long to prevent burnout?
Old May 19, 2026 | 03:39 PM
  #30
wymjym's Avatar
I wouldn't think so or what use would it have at a stop light etc?
wj
Old May 19, 2026 | 05:13 PM
  #31
Cee Jay's Avatar
Maybe that troublesome diode is slowly failing?
Unhingd
Jan 13, 2025 06:51 PM
raphsp3aks
Sep 19, 2024 02:42 PM
technabob
Sep 20, 2020 03:19 PM
milleniumaire
Jan 29, 2014 10:05 AM
Padrino
Mar 21, 2013 02:29 AM
