4.2L oil pan persistant leak
Old Today | 09:06 AM
luv2fly's Avatar
The M113 5.0L Mercedes engine valve covers and crankcase breather covers are notorious for leaks. I've read it's almost always a result of the o-ring groove not being clean enough. The breather covers don't have an o-ring and are supposed to be sealed with a specific Mercedes sealant. It's like trying to squeeze asphalt out of a tube. I've recently seen Permatex Gear Oil Gasket Maker for differential covers recommended. On my 3rd attempt, I used Red Hi Temp RTV. Not the prettiest result, but stopped the leaks.
If you have to redo this job, you might make certain the o-ring groove is spotless, but also use the Gear Oil gasket maker in a thin coat on the oil pan rail itself.
In my case, I just want the leak to stop. Pretty doesn't enter into it.
Hopefully, in your case, it doesn't leak again.
johns55
Jan 17, 2024 04:00 AM
Bill C
May 25, 2016 08:04 PM
Michigan
General Tech Help
Mar 12, 2008 08:12 PM
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
