5.0: Engine fan running after engine switched off?
Old Jul 11, 2023 | 01:42 PM
earny's Avatar
Default 5.0: Engine fan running after engine switched off?
Hi colleagues,
I noticed with my XK 5.0 (2010) that at the current very high temperatures and running air condition with hot engine the radiator fan runs on a low, almost inaudible stage - after turning off the hot engine, even this low ventilation stage switches off immediately. No symptoms of overheating, car is running fine.
Shouldn't a higher ventilation level continue to run for a short time after the engine is switched off? How is that with your X150, especially with the 5.0 engine? What to look at - possible fault?
Thx and greetings from Cologne!
bernd
Old Jul 11, 2023 | 03:22 PM
RichardS's Avatar
It sounds right to me.
Richard
Old Jul 11, 2023 | 04:13 PM
ptaylor2000's Avatar
It is eerie that when I push off that everything,, air conditioning, engine fan, radio, is immediately..well, off!
With the engine off continuing to run the fans might cool the radiator but, because there was no coolant circulation, not the engine block.
Old Jul 12, 2023 | 12:51 AM
earny's Avatar
Thx all, after use in hot conditions at least at my X308 XJR the engine fans run about 1 or even 2 minutes after engine off, what brings obviously the high temperatures down under the bonnet.
Old Jul 15, 2023 | 04:55 PM
Brewtech's Avatar
It forces the hot air out of the engine bay faster than if you were to let it sit.
jcb-memphis
Jan 22, 2023 12:55 PM
D.C.
Dec 9, 2021 09:43 AM
GetITcoy60
Jul 20, 2021 08:22 AM
Zereldo
May 18, 2021 10:28 PM
unionjack42
Feb 5, 2013 07:06 AM
