5.0 timing chain rattle on cold start
Old Jul 31, 2022 | 12:22 PM
jahummer's Avatar
Post # 10
https://www.jaguarforums.com/forum/x...-chain-246239/
Old Aug 11, 2022 | 03:03 AM
trkyam's Avatar
Finally got a decent recording of my timing chain cold start noise,
some days are worse than others. Does this sound normal??
Old Aug 11, 2022 | 03:10 AM
trkyam's Avatar
2010-2012ish 5.0 uses the bottom chain..
Old Aug 11, 2022 | 03:45 AM
RichardS's Avatar
Originally Posted by tarokyama
https://youtube.com/shorts/PvevmXs5eAs?feature=share
It is so difficult to tell from recordings due to the quality of the recording and reproduction systems but I can't say that I can hear anything particularly untoward.
Richard
Old Aug 11, 2022 | 11:23 PM
trkyam's Avatar
Driving home today stalled out threw obd code # p0340 crank
no start, did I just skip timing? waiting on a tow now
Old Aug 12, 2022 | 12:17 AM
trkyam's Avatar
Crank syrong gas smell, no start.
occasioannally the crank sounds like its hitting something.
Pretty sure I just lost my timing...
Old Aug 12, 2022 | 01:34 AM
trkyam's Avatar
Old Aug 12, 2022 | 01:45 AM
  #28
trkyam's Avatar
Pretty sure im screwed.
Old Aug 12, 2022 | 02:13 AM
RichardS's Avatar
That's really bad. I feel for you.
The most common problem with the earlier 5.0 tensioners is the alloy insert which forms the pad against which the hydraulic tensioner operates. Being relatively soft, this wears until the tensioner runs out of travel. Why JLR thought that saving a few grams by not using a steel insert was a good idea is beyond me.
Richard
Old Aug 12, 2022 | 03:49 AM
  #30
trkyam's Avatar
You were spot on Richard,
I hope others will learn from my mistakes.
My chain rattle was very very light
and only on cold start.. into the shop tomorrow
this is beyond my expertise although the motor cranks just fine
the PCM wont allow spark cause the timing is too far off.
Old Aug 12, 2022 | 04:34 AM
  #31
Ter11's Avatar
Dear Tarokyama,
I also feel for you with this issue and I so much appreciate that you keep us updated on this.
I understand your car suffering this issue is a 2010 XK. Not sure you mentioned your mileage though - I would be very interested to know at what mileage you started to notice the chain noise issue on startup.
Not without reason I am following here with great interest. I drive a 2011 XK with approx. 35k miles on the odo (it has the narrow version of the chain as visible trough the oil filler hole, see pictures above).
br
ter
Old Aug 12, 2022 | 03:23 PM
  #32
trkyam's Avatar
UPDATE, my mechanic suspects injector failure,
and not timing chain, I did do the valve cover gaskets
and clean injectors mechanically 3 weeks ago.
Upon stalling I had tons of smoke out the exhaust.
which is why he suspects injector failure, (common)
I will update after he does a compression test and inspects
The valves and injectors.
Mileage is 69k
Old Aug 12, 2022 | 04:07 PM
  #33
RichardS's Avatar
Mileage is 69k
My fingers are crossed.
Richard
Old Aug 12, 2022 | 04:27 PM
  #34
Cee Jay's Avatar
If the exhaust smoke was black, then yeah, probably injector.
As a caveat to that, all the raw fuel in the exhaust can easily foul the catalytic converter. Watch for codes once your car is running again. Also maybe as a pre-emptive, run a can or two of Catalytic Converter Cleaner through the fuel.
Old Aug 12, 2022 | 09:36 PM
  #35
trkyam's Avatar
It was an injector! Stuck open!!!,
waiting on parts but my mechanic
warned that fuel got dumped into the cats..
Old Aug 12, 2022 | 09:39 PM
  #36
Cee Jay's Avatar
BTDT,GTTS.
Old Aug 13, 2022 | 12:12 AM
  #37
Ter11's Avatar
Great!!!
Old Aug 27, 2022 | 09:00 PM
  #38
trkyam's Avatar
Pulled spark plugs from cylinder 1 and 2 on drivers US side,
heres what I got any thoughts?
Im changing all the spark plugs and 1 bank of injectors
apparently removing injectors with the alide hammer is
detremental to your injectors
Im back up and running and my fuel trims on one bank
have zerod out at idle. Amazing.
70k miles original plugs after injector failure and engine flood.
Old Aug 28, 2022 | 02:32 AM
  #39
RichardS's Avatar
I would be happy with those. 🙂
Richard
Old Aug 28, 2022 | 04:31 AM
  #40
trkyam's Avatar
Thank you everyone for your support.
you guys are amazing.
Peter Lee
XJ XJ12 ( X305 )
Sep 25, 2020 03:11 AM
Calvey
Jul 23, 2019 04:38 PM
jhxj6
Jun 7, 2014 08:48 PM
AlbBolivar
Oct 2, 2013 04:28 AM
Grant Francis
Mar 23, 2010 04:54 PM
