600BHP+ results on 5.0 s/c
Old May 9, 2023 | 02:22 AM
tmich's Avatar
Default 600BHP+ results on 5.0 s/c
Hi!
I have finally managed to cross 600bhp with my car (MY10 XKR). It required both lower and upper supercharger pulleys replacement. But... Before the lower pulley it was increasing the power till the very end. Now - it dies at 5000-5200 rpms.
I'm wondering about the root cause. First hypothesis- wastegate releasing additional boost. Are these 600+ bhp builds do any changes to the wastegate? Probably it is easier with newer models as they have an electronic one. Here - it is the older version...
Any thoughts?
Upper pulley:
upper and lower pulleys:
Old May 9, 2023 | 03:26 AM
equatorial's Avatar
Not that you ever would, but that flat torque curve would make this a tow rig that could shame a diesel.
Old May 9, 2023 | 05:01 AM
OzXFR's Avatar
The AJ133 SC is renowned for it's flat torque curve.
From memory a stock engine from the factory is quoted as making max torque from 2,000 to 4,500 rpm.
Old May 9, 2023 | 06:10 AM
jons's Avatar
Originally Posted by tmich
Any thoughts?
valve float?
Old May 9, 2023 | 07:34 AM
tmich's Avatar
Originally Posted by jons
valve float?
interesting input- need to think about it. Car has equal compression on each cylinder, but not sure if it matters in this case.
Old May 9, 2023 | 11:43 AM
Ricky5.0s/c's Avatar
Hi!
Any thoughts?
Upper pulley:
your car is capable to push over 700hp on upper pulley only. The ecu tune is what's holding it back that's why it made less power after the crank pulley because now u making more power alot sooner and all the torque limiters kick in. Nobody has been able to remove this limiters sadly
Old May 9, 2023 | 11:45 AM
No Quarter's Avatar
Fuel pump can't keep up? Fuel filter clogged? Whole fuel delivery system built to support less HP?
Old May 9, 2023 | 11:59 AM
tmich's Avatar
rather it's not the case - we were able to add more fuel, but it didn't make any difference.
Old May 9, 2023 | 02:01 PM
clubairth1's Avatar
Community Influencer
What tuner are you using?
Old May 9, 2023 | 04:09 PM
tmich's Avatar
i'm in Poland - local company (you have a name on the dyno chart).
Old May 10, 2023 | 12:09 AM
Barry Leftwich's Avatar
Hi!
Any thoughts?
Upper pulley:
Don't you need to reprogram/tune the ECU so it could recognize the new power your car putting out?
Old May 10, 2023 | 01:20 AM
tmich's Avatar
well, yes it is obviously done (without it it would be actually below OEM power as it would be highly "overfueled").
Old May 10, 2023 | 02:50 AM
Idk how else to help cause all I know is once you do something to a car to upgrade the horsepower, everything else including the transmission gotta be tuned to recognize the new modification from what I was told by a mechanic that know how to do serious mods on cars that build hot rods and things
Old May 11, 2023 | 12:20 AM
u102768's Avatar
This is the info I got back from a well know tuning company when I enquired about doing both pulleys:
"The only issue I’ve ever run into is if both upper SC and lower Crank are installed on a Denso equipped vehicle, a lot of playing around with the file needs to be done or else the excessive boost is vented off. For the time being, we’ve gone the route of NOT recommending both pulleys on a Denso equipped vehicle. But in your case with just the upper pulley, shouldn’t be any issue providing it’s tuned “correctly”."
The later cars e.g. F Type, have electronically controlled supercharger boost valves so can be tuned better. The Denso ones are mechanical.
There is a lot of information in this post about supercharger pulley sizes and combinations:
https://www.jaguarforums.com/forum/f...1/#post2136732
Old May 11, 2023 | 05:11 AM
MoscowLeaper's Avatar
Here's Denso dual pulley setup, right before a trans remap (trans was limiting torque).
However now i can make same numbers with a stock pulleys (benefits in avoiding a traction problems).
Same day, same hour, same dyno, stock tune in a PCM.
Old May 11, 2023 | 05:40 AM
tmich's Avatar
When you look at my dyno chart - what is your hypothesis? Purely software issue?
Old May 11, 2023 | 05:50 AM
Either a softare or a bypass plate wear.
Old May 11, 2023 | 06:55 AM
tmich's Avatar
Pardon my ignorance- by bypass plate you are referring to the actuator (C2D9331) or other part? I'd be grateful!
Old May 11, 2023 | 07:05 AM
It's a throttle plate inside a supercharger, driven by bypass actuator.
Old May 11, 2023 | 07:31 AM
tmich's Avatar
Is there any way to test it without taking off and disassembling the whole supercharger?
