active exhaust
Old Oct 25, 2014 | 01:15 PM
kj217's Avatar
Default active exhaust
i did pull the fuse to keep the valves open,, but i also found the vacuum lines disconnected from valve actuators by previous owner,,
i noticed that outter tail tips are cleaner than inner,, i also found no air coming from outter tips at idle,,
do i have the valves open or close by removing fuse/vacuum lines?
Old Oct 25, 2014 | 03:02 PM
Stuart S's Avatar
I suspect, but don't know for sure, that disconnecting the vacuum lines keep the valves closed since you have exhaust flowing through only 1 pipe. When the valves are open, exhaust flows through both pipes.
Just my WAG.
Why disconnect the vacuum lines? Have they been plugged? If not, how does your car run and does your check engine light come on? Why not plug them back in?
Stuart
Old Oct 25, 2014 | 04:28 PM
powerhouse's Avatar
I have a milltek system on my 07 xkr with no valve system and the 2 vacum lines have been plugged with a bolt. As the system was on when i bought the car i contacted them about the pipes and was told that they are just blocked when not in uses. Fuse 19 is still in and no cel light, don't know whether it effects anything.
Old Oct 25, 2014 | 06:29 PM
Lothar52's Avatar
How do you like the milltek system....
was thinking about upgraded my 2 silencer and a bladder non-performance active exhaust system to either the stage 3 milltek or a quicksilver super sport system... Any thoughts?
Would it be louder and... gruntier??!!?!
Old Oct 26, 2014 | 01:04 AM
kj217's Avatar
Just my WAG.
Stuart
the lines are plugged with bolts and car runs fine,, no CEL,,
what drives the vacuum in those pipes? electric pump?
boiler
US Southwest
Dec 20, 2025 12:38 AM
jdzubas
Oct 4, 2015 09:14 AM
XJ8JR
Oct 2, 2015 12:13 AM
baskervillema
Oct 1, 2015 06:43 PM
