Adaptive headlight adjustments
Old Oct 10, 2014 | 03:00 PM
jagtoes's Avatar
Default Adaptive headlight adjustments
2012 XKR and I am not satisfied with the height of the low beams. They seem to not project as far as I think they should. I see the adjustment L-R (lower - raise) in the headlight assembly but before I adjust them does anyone know how much a 1/4 turn will raise them . Just wanted a starting point so I don't bring them up to high. I usually start with about 1/8 turn . As funny as it was I remember on the seal beam headlights they had protrusions on the lens which I had a alignment fixture to adjust them both up and down and side to side. I guess it was to simple then LOL.
Old Oct 10, 2014 | 04:25 PM
Stuart S's Avatar
Assuming your car is garaged and the floor is level (and you park nose in), when it's dark enough back out a few feet and mark the garage wall with masking tape where the centers of the R and L low beams hit the wall. Also mark the floor so you can position the car in the same place if you need to make adjustments again. With the wall marks as your guide, make the headlight adjustments and mark the final positions on the wall. Test drive and if not to your liking adjust again until you're satisfied.
Hope this works for you.
Old Oct 11, 2014 | 09:17 AM
Lothar52's Avatar
Can someone send me a pic of the L-R adjustment knob I need to do this myself!
Old Oct 11, 2014 | 03:51 PM
u102768's Avatar
I haven't touched them myself but here you go.
MrWhite
19
Jun 14, 2022 07:49 PM
Johncy2000
Oct 2, 2015 01:05 AM
gunlocators
Sep 30, 2015 08:05 AM
kevinl
Sep 24, 2015 08:25 PM
