Advice please before I buy - Error Codes
Old Jun 25, 2021 | 12:49 PM
SteveX150's Avatar
Default Advice please before I buy - Error Codes
Hello from a first time poster.
We have our eye on a 2008 XKR convertible and have had the car inspected by a local Jaguar dealer who carried out a pre warranty inspection on the car for us so we could get the best health check before committing to buy it.
I did quite a bit of research on the X150 XKRs before going to see it so was aware of the damp passenger footwell problems and noisy VTT. Both were fine on this car.
Overall the car has clearly been well looked after. It has done under 30K miles and pretty much a full dealer service history. Visual inspection picked up the odd little mark on the paint but other than that it's in VGC. Test drive was dammed near perfect, smooth as a button and no noises to be concerned about.
It does need a new condenser but that's been factored into the price which I think is a good price compared to others on the market.
What I need help on is the error codes that the inspection showed up. I know the car has had a flat battery a few times as it only does about 1,000 miles per year with the current owner. Are the codes massive red flags or is this pretty normal for a car of this age. I understand that cars generate fault codes all the time, especially when the battery goes flat.
The car pretty much sailed through the inspection otherwise which is not bad bearing in mind it's 13 year old.
Any advice would be greatly appreciated before we confirm the purchase.
Many thanks
Steve
Old Jun 25, 2021 | 02:52 PM
Cee Jay's Avatar
Wow. That's sort of what mine looks like, but I've got 69,000 miles.
Also, a lot of those codes ARE battery related and probably 'fixed' themselves with the install or charge of the battery.
Speaker #6 lost? That may be something, but trivial. Maybe a panel was removed for some reason, along with that speaker.
Heated windshield.... you don't say your location on this huge planet, so it's difficult to say you even have that option.
Old Jun 28, 2021 | 02:20 AM
SteveX150's Avatar
Thanks Cee Jay
Appreciate the feedback.
I did spot the 6th speaker and heated windscreen faults.
Speaker - not to worried about that
Heated Screen - we're in the UK but the car is going to be a summer runner, and will be rested over winter so that's not an issue.
Hoping to we can get the car's paperwork sorted out this week.
Old Jun 28, 2021 | 04:11 AM
JonWat's Avatar
You definitely need to get a battery trickle charger & hook it up when not in use, otherwise sounds good. Enjoy.
Old Jun 28, 2021 | 04:13 AM
SteveX150's Avatar
Thanks John
Trickle charger already on order
Roberto Caria
Jan 22, 2019 03:08 AM
bklynchris
Jun 15, 2018 12:53 PM
Fishnmagician
General Tech Help
Jan 7, 2017 04:05 AM
JagRag
Apr 24, 2015 07:59 AM
Datru
May 5, 2013 02:25 PM
