Air conditioning barely blows, and just in a certain temperature range
Old Jun 29, 2022 | 11:01 AM
  #41
George Abitbol's Avatar
Originally Posted by George Abitbol
But just to make sure: would water get into the passenger footwell if the duckbill is off?
Another question: I have found the hole where the duckbill is located. But I can't feel it at all!
I have fairly short fingers, but isn't it supposed to stick out from that hole?
On the attached drawing, which is the actual positioning of the thing? A or B?
Thanks!
Old Jun 29, 2022 | 01:19 PM
  #42
kj07xk's Avatar
‘B’ is something like it. The duckbill is up inside the hole you find above the tranny.
Old Jun 29, 2022 | 01:25 PM
  #43
Just to clear any potential confusion: the black "L's" (and inverted L's) in the drawing all represent the sides of the hole where the duckbill is located. The inverted L on the left of A & B is not the transmission.
The bottom of the picture therefore corresponds to the direction of the bottom of the car.
So taking this into account, is it still the B configuration?
Old Jun 29, 2022 | 07:22 PM
  #44
jahummer's Avatar
Pics here
https://www.jaguarforums.com/forum/x...-182608/page2/
Old Jun 29, 2022 | 08:51 PM
  #45
kj07xk's Avatar
Yes.
Here is a lengthy thread on the topic:
https://www.jaguarforums.com/forum/x...lution-149349/
Old Jun 29, 2022 | 08:58 PM
  #46
kj07xk's Avatar
See post #7 by flyc2c in this thread;
https://www.jaguarforums.com/forum/x...ve-box-167968/
Old Jun 29, 2022 | 09:33 PM
  #47
Cee Jay's Avatar
Also:
Old Jun 30, 2022 | 05:22 AM
  #48
Originally Posted by Cee Jay
Also:
That's precisely what puzzles me...your above pic suggests configuration "A" in my drawing (see post #41), with the duckbill even sticking out...which I could not feel at all.
However, in the last pic of this pdf it definitely looks like configuration "B", with the tip being horizontal and pointing forwards : https://www.jaguarforums.com/forum/a...ion-ac-fix.pdf
Can it be different from one model to the other?
Old Jun 30, 2022 | 09:02 AM
  #49
Cee Jay's Avatar
It appears to be more of a 45-degree angle than perpendicular. So, more between the two diagrams.
Old Jun 30, 2022 | 08:06 PM
  #50
JeremiahLovesJags's Avatar
this has been a nightmare for me, good luck to you, for most people it is as easy as replacing the resistor or fan, I have put them in and out multiple times on my xk trying to test why its still not working, so it shouldn't be that bad to do it once, the glove box is easy to remove, just unplug all the connectors, and then the actual motor and resistor is 2 screws for resistor and 3 screws for fan, no dash removal for this.
oldie
Aug 23, 2015 12:37 PM
thesameguy
Jul 1, 2015 05:02 PM
NTL1991
XJ40 ( XJ81 )
Oct 28, 2013 09:37 AM
megatrack
Oct 18, 2011 05:31 PM
