Air Conditioning Condensation Leaking int passenger cabin
I have an '08 XK and I am experiencing water leaking into the passenger cabin when air conditioning is used. I thought that it was simply a blocked drain line that needed to be cleaned or blown out but local tech/jaguar authority advised that correcting the problem is much deeper and that it could require separating the engine from the transmission (an ominous and expensive solution). Can the drainage problem be corrected more easily and less expensively?
It may be too late... Once a year, every year, I adjust the climate control to direct air strictly through the vents. Then put the fan on high and close all vents for a few mins.
This simple procedure has kept the duckbill working properly.
Nice big puddle on the ground next to the gas pump.
That's a very good tip.
See: https://www.jaguarforums.com/forum/x...lution-149349/
Good luck!
Stuart
I dodged a bullet. I will take your advice and do this periodically to keep the line open. Much appreciated
If your "duckbill" hasn't been cut I still would suggest doing so. Fortunately, when I bought my 07 XKR 11 years ago it had been done. Unfortunately, the damage had been done and the standing water in the plenum had taken out the blower motor. Jaguar motors are quite expensive, and I was able to come up with an alternative procedure to replace the OEM motor. I had posted the procedure on the forum and it may still be there if you need to do a motor replacement.
