Alcon Brake issue
Old Apr 28, 2019 | 04:58 PM
McJag222's Avatar
Default Alcon Brake issue
Hey guys, not been around for a while.
I have been getting some steering shimmy under braking - took the wheels off checked the disc run out with a dial gauge thinking I may have a warped rotor - all good.
I noticed that caliper was very close to the disc on the top end, removed the bolts and pushed the caliper back a little and noticed that there is signs of wear where the disc rotor has been rubbing. See pic:
There seems to no play in the bearings so I can't account for this.
Any ideas here?
Thanks - Mac
Old Apr 28, 2019 | 05:11 PM
McJag222's Avatar
Forgot to add 2009 XKR.
Old Apr 29, 2019 | 01:57 AM
steve_k_xk's Avatar
If the rotor is making contact with your caliper I have no doubt your rotor is shot .
For future reference to any forum members if you get brake shudder on the brake pedal when applying the brakes it's read rotors if you get shudder through the steering wheel it's the fronts
Old Apr 29, 2019 | 12:54 PM
gkubrak's Avatar
Not sure how that would happen ... I would suggest making sure the caliper and bracket are seated correctly and torqued to spec.
Old Apr 29, 2019 | 01:14 PM
McJag222's Avatar
Thanks guys. I've ordered a new rotor (the current one has very little wear). I'm going to pull the wheel off this afternoon and check the caliper mounting "system".
More later.
kyle191
Oct 14, 2023 09:29 PM
AirCav
Jun 14, 2019 05:25 PM
SteveM
Dec 15, 2015 09:15 AM
Stuart S
Oct 12, 2015 07:45 AM
theironman
Jul 18, 2011 08:27 AM
