Ambient air temp reads 0 degrees F - RESOLVED
Old Jan 23, 2018 | 09:19 PM
Patrick Wong's Avatar
Default Ambient air temp reads 0 degrees F - RESOLVED
My 2007 XK has logged 81K miles. I've noticed that on an intermittent basis the ambient air temperature as displayed on the screen will erroneously read 0 degrees F. The actual air temperature is greater, 50 - 60 degrees F.
The air conditioning and heating system works fine regardless.
Has anyone else noticed this; and if so did you determine the cause of this problem? Thanks!
Last edited by GGG; Jan 24, 2018 at 05:25 AM. Reason: Add "RESOLVED" to thread title
Old Jan 23, 2018 | 09:28 PM
Sean W's Avatar
Your answer attached Patrick. Not worth fixing imo.
Old Jan 23, 2018 | 10:06 PM
pwpacp's Avatar
Yeah, my 07 did the same thing. It happens at 58 degrees, right? Like Sean says, it is not worth trying to fix, just a niggle.
Old Jan 24, 2018 | 05:28 AM
I've added RESOLVED to the thread title.
The solution is in post #2 but with "at least two hours to download" hooked up to dealer diagnostics, I don't expect too many will be rushing to apply the fix.
Krisfx
Jan 18, 2022 06:07 AM
Grant Francis
Mar 29, 2017 06:11 AM
MRomanik
Aug 15, 2016 05:57 AM
kmarajh
Jan 24, 2016 07:21 AM
jdmcomp
May 22, 2013 05:31 AM
