Ambient temperature fault.
Old Mar 20, 2026 | 05:07 PM
Djv750's Avatar
Default Ambient temperature fault.
I have a problem with the ambient temperature on my XK. The display continually fluctuates between -40 and the current air temp (64F today) As the display alters the grey relay behind the rear seat clicks in unison. I have replaced the sensor behind the front bumper with a genuine JLR part but that has made no difference.
Any help or suggestions will be greatly appreciated
Old Mar 20, 2026 | 07:11 PM
kj07xk's Avatar
Is that -40 C or F?
Old Mar 20, 2026 | 07:25 PM
kj07xk's Avatar
The reason I ask about C or F, is that depending on your VIN, you may have the issue in the following thread. There is a TSB attached in the thread with more details.
Ambient air temp reads 0 F
Old Mar 21, 2026 | 06:07 AM
Djv750's Avatar
I will take a look. But it happens all the time whether Ive set the display to C or F
Old Mar 22, 2026 | 01:42 PM
sony2000's Avatar
Because -40F is the same as -40C in the real world? Change the relay?
Old Mar 23, 2026 | 12:18 PM
JagV8's Avatar
If it's swapping as described maybe a bad connection. I think -40 is the same as either an open- or short-circuit sensor.
(Yes, -40F = -40C)
sony2000
Nov 28, 2024 09:33 PM
Larry-Cleveland
Jan 12, 2018 09:07 PM
Steve.c3h8
Dec 28, 2017 12:00 PM
lazerbrains
Nov 29, 2011 11:22 AM
timxtype02
Mar 18, 2008 09:19 PM
