ASF headlight fault
Old Jun 25, 2025 | 12:33 PM
Radek Sadowski's Avatar
Default ASF headlight fault
Right hand side lense is pointing down and center the other one is fine. I have switched the module and then the fault followed i.e. the left hand lense was pointing down and right hand was fine. I’ve ordered a used part but it made no difference. My ‘good part’ behaved correctly and the fault followed the replaced second hand part. Is the used part also faulty or is there another fault that makes it misbehave?
Old Jun 25, 2025 | 01:31 PM
Stuart S's Avatar
Why did you start a new thread, when you already asked the same question here? https://www.jaguarforums.com/forum/x...ocking-290122/
Are you sure that used eBay module is the correct part number for your car?
Old Jun 25, 2025 | 01:33 PM
Yes it’s definitely the correct part, identical numbers.
Old Jun 25, 2025 | 01:37 PM
miles61's Avatar
Hi, I never swapped modules when mine did that, but I had an issue with the front height sensor, I replaced that and they both tracked properly after.
Old Jun 25, 2025 | 01:39 PM
Stuart S's Avatar
Is this how you replaced that module?
https://www.jaguarforums.com/forum/x...cement-272148/
Old Jun 25, 2025 | 01:41 PM
Where is the module located and how do you replace it? Also I’ve taken the heels off to check the ground but there were no grounding cables in the wheel arch.
Old Jun 25, 2025 | 01:42 PM
Thank you!
Old Jun 26, 2025 | 06:40 AM
slb07jagxk's Avatar
Default Headlamp Fault
Did you get a warning light on your dash?
Old Jun 26, 2025 | 07:38 AM
Yes I did so back to square one
Gerald Clark
May 16, 2024 08:03 PM
rgp
Sep 15, 2021 01:22 AM
prasville
Jun 8, 2018 03:36 AM
05XK8cfe
Jun 11, 2017 08:39 AM
Jimmy280
May 6, 2016 03:53 PM
